BC stage 2 cams pic request
Old Oct 16, 2011 | 02:09 PM
mgrotel's Avatar
mgrotel
Default BC stage 2 cams pic request
If you have put these cams in, I need to know which way each dowel pin is supposed to face. Pretty sure the intake cams should have the pin on the bottom and the exh cams should have the dowel on the top side. If this is correct, what position did you install the right bank ones?
Old Oct 16, 2011 | 02:48 PM
mgrotel's Avatar
mgrotel
Someone has to know this
Old Oct 16, 2011 | 03:27 PM
the_coupe's Avatar
the_coupe
you will actually have to pull the dowel pins out for the intake cams cuz the sprocket itself has the lil pin to line it up with.
Old Oct 16, 2011 | 03:33 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
+1 on the dowel removal.
This may be the only pic I have of my cams installed
Old Oct 16, 2011 | 03:59 PM
mgrotel's Avatar
mgrotel
ok, thanks guys. the factory service manual says, for the intake cams, the little hole should be on top, and the large hole on the bottom, the large hole being the one with the dowel in it that i will have to remove. the fsm says, for the exh cams, that the dowel should be on the top. so, here is what i have, i will just need to rotate the right bank (left in pic) cams to where they will line up like the left bank (right in pic) cams do. does this seem correct?
350Z_Al
Oct 29, 2020 07:44 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
