Pro Am Drift/Nasa TT Build Begins
Old May 18, 2012 | 10:23 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
nice build
Old Jun 1, 2012 | 08:23 AM
350zJDMnismo27's Avatar
350zJDMnismo27
Bump. Got a question guys will be putting the motor back in this weekend wondering how I am going to start it since I will be putting a new ecu in. Do i need to go to the dealer to have them re program it or can I by pass and put a switch on
Old Jun 4, 2012 | 08:23 AM
350zJDMnismo27
Old Jun 4, 2012 | 10:31 AM
laze1's Avatar
laze1
Spec Z is the new class....look at nasaproracing.com for the rules....and nasaforums.com has a section for Spec Z info
Old Jun 4, 2012 | 10:33 AM
laze1's Avatar
laze1
TTC or TTB are the best classes for a 350z....read the rules very closely....that will help guild your build
Old Jun 11, 2012 | 07:42 AM
350zJDMnismo27
Old Jun 11, 2012 | 09:58 AM
Quamen's Avatar
Quamen
I would ditch the UR crank pulley for racing and get a good damper.
Did you weld the heater outlet shut?
Old Jun 11, 2012 | 10:08 AM
350zJDMnismo27
The plate is bolted on not welded. I have heard mix reviews on that UR pully
Old Jun 11, 2012 | 10:15 AM
Quamen's Avatar
Quamen
I was gonna say. The angle just makes it hard to see that its a plate and I thought you just put the bolts back in. I did the same thing on my VQ when I still had one.
Old Jun 11, 2012 | 12:09 PM
str8dum1's Avatar
str8dum1
move to NA builds subforum.....
Old Jun 11, 2012 | 06:19 PM
Dynosty's Avatar
Dynosty
FYI, it appears you are installing a VQ35DE Revup, not an HR. Good looking build up though. I too would recommend ditching the UR pulley... ATI would be my suggestion.
As for startup, we can flash your new Revup-capable ECU to disable NATS so you can start/drive it.
Old Jun 18, 2012 | 07:56 AM
350zJDMnismo27
Old Jun 18, 2012 | 08:25 AM
ibelonginprison's Avatar
ibelonginprison
oh snap... got the faux firewall shave going on. Gonna look a lot like Bryan Settle's track Z. Love it!
Old Jun 27, 2012 | 11:36 AM
Dan@Assaultech's Avatar
Dan@Assaultech
Subscribed, can't wait to see her on the track Scott!!
Old Jul 2, 2012 | 07:49 AM
350zJDMnismo27
Old Jul 3, 2012 | 07:24 AM
350zJDMnismo27
THANKS DAN!
Old Jul 3, 2012 | 07:59 AM
350zJDMnismo27
Now to bypass nats and get it started without re flashing the ecu for $300
Old Jul 3, 2012 | 08:30 AM
  #38
Voboy's Avatar
Voboy
For 200$ more you can buy uprev tuner and disable NATS yourself. no need to get a new key or anything, and gives you more options like the ability to get the a/f and cams tuned.
How much weight was the false firewall anyway? i can't imagine its much, but i'm curious. wondering if theres any impact on interior heat without it.
Old Jul 3, 2012 | 12:45 PM
  #39
djamps's Avatar
djamps
Tuner is $700 including cable last time I checked.
It's $300 to have a pro-tuner flash it for you.
Old Jul 3, 2012 | 02:32 PM
  #40
Voboy's Avatar
Voboy
Oh whoops forgot how much it was. But i looked and bought mine for a little under $600 a year ago. Still not bad to have if you lke/know how to tinker with it.
