Rev-up swap in a 2003 z33
Old Jan 3, 2013 | 05:32 PM
jwttz's Avatar
jwttz
The flywheel is 9 lbs and the clutch discs, pressure plate, and hardware are a little over 9lbs. It's a steel flywheel so it's a lot stronger that's the tilton ones which were aluminum I think.
Old Jan 3, 2013 | 05:46 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
That thing tacs like a mf. I can hear the chatter which is awful but who cares its a track car. How's that clutch flywheel DD?
Old Jan 3, 2013 | 06:01 PM
jwttz's Avatar
jwttz
Honestly I don't think I would daily drive it. You could, and I have driven it around town, but it is just not worth it. There is a lot of chatter but its also a stripped interior. The chatter dosent sound bad outside the car.
Old Jan 3, 2013 | 07:09 PM
INTIMAZY's Avatar
INTIMAZY
The Tilton was also chromoly. If it was aluminum, it would have shattered itself to pieces! Wonder what the MOI of the Aasco is... any idea? Not sure if they would publish that spec.
Chatter is a given with these style clutches, especially with small 7.25" or 5.5" clutch assemblies with very low inertia.
Old Jan 3, 2013 | 07:40 PM
jwttz's Avatar
jwttz
I don't recall, they gave me that info when I picked it up though. It's the 7.25" unit.
Old Jan 4, 2013 | 10:54 PM
terrasmak's Avatar
When is your next day at the track with it?
Old Jan 5, 2013 | 02:01 PM
jwttz's Avatar
jwttz
Dunno. I am in the middle of moving and job training. I would like to get to the track before the month is out though.
Old Jan 12, 2013 | 12:00 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Quick question, do you have the RJM Bracket?
Old Jan 12, 2013 | 12:46 AM
jwttz's Avatar
jwttz
Uh no. I have the wilwood master cylinder and a steal braided line. You can adjust with that at the pedal. Not sure what it does exactly. I also have the Nismo shifter with a poly bushing I made myself.
Old Jan 12, 2013 | 09:17 AM
RJM Performance's Avatar
RJM Performance
Vendor - Former Vendor
Thumbs up
The RJM Clutch brackets go far beyond simply adjusting the threaded clutch rod. The AFP slider mechanism and accompanying replacement brackets alters the leverage point of the pedal system by physically changing the linkage geometry and pivot points. Allowing even tripple disk OS Giken's to be daily drivable in traffic with a much wider engagement range.
Links in my sig if you'd like to look more into it. Also a 16 page review thread in the forced induction/drivetrain tech section here.
Old Jan 13, 2013 | 01:15 PM
jwttz's Avatar
jwttz
Ah, that's good to know. Sounds like a must if you we're to try and DD this kind of setup.
Old Feb 13, 2013 | 11:26 PM
Vq.turbo.DremZ
How much was the clutch and flywheel?
Old Feb 14, 2013 | 02:51 PM
jwttz's Avatar
jwttz
It was about $2400.
Old Jun 11, 2015 | 01:20 PM
Rozeth Chhem's Avatar
Rozeth Chhem
Saved my life.
Old Jun 11, 2015 | 01:51 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Originally Posted by Rozeth Chhem
Saved my life.
An old thread from two years ago saved your life!?
sales@czp
Sep 23, 2019 03:30 PM
