Just another v8
hey, what are you using to mate the fast fuel rails to your fuel system? Do you have a fuel return system?
I was told that even if I dont use a fuel return system I need to use something like the CJM Stage 0 return system which only serves to mate the oem system to the arftermarket fuel rails.
Thanks
Thanks
Thanks
Thanks
So I got my new intake installed, couple things left.
Here is some information!
It is HOLLEY MID RISE INTAKE not a HIGH RISE, the mid rise is made for smaller CI, the High is for big CI and a lot of boost!
Does it fit under the hood? No
Im either going to make a real clean hole or first im gonna make my engine mounts a 1/2in shorter and use hood spacers in the rear.
The quality is MUCH better then the FAST 102.
I wont know the power difference until I get the car retuned at Dynosty by Hal which who previously tuned the car. And the intake is the only change so should be a good comparison. I didn't switch for HP tho, I mean whats 5hp? I swiched cause I think it looks way better! And its not plastic!
So here are some pictures.
BONER
BONER
So I think im going to try to move my engine back some about an inch and lower is a 1/2 in tomorrow. should beable to just drill come new holes in the mounts and cut some off my custom solid mounts. Ill post pictures tomorrow and let you guys know how it goes!
So I got the car running again! But we have had a lot of snow so I haven't been able to drive it! I will for sure this Saturday! Cant wait to see how the car feels! Also im picking up some hotchkis swaybars this Friday! Here is picture with everything installed!
Need install my sideskirts and bumper! Vinyl wrap wont be much longer!
Cool build - good luck!
