Tire Pressure ?
Old Dec 1, 2007 | 05:26 AM
JungleJunkee's Avatar
JungleJunkee
Default Tire Pressure ?
Hey, last night the temp in toronto dipped down to -10 or lower and my tire pressure light came on. I checked the psi and it is showing 28 front tires and 27 back tires. I'm guessing because the weather is so cold that the tire lost pressure, so how much should the psi regularly be and how much air should i put in ?
thanks in advance
Old Dec 1, 2007 | 01:53 PM
Bary626's Avatar
Bary626
thanks in advance
Should tell u on label when open driver door?
I believe it's sould be 35 PSI which trim model u have?
Old Dec 2, 2007 | 02:02 PM
ZR_Yancy's Avatar
ZR_Yancy
If it doesn't have stock tires, then refer to the sidewalls for proper psi for that particular tire.
Old Dec 2, 2007 | 02:06 PM
SniperHunter's Avatar
SniperHunter
34 all around for 18s, I believe.
Old Dec 2, 2007 | 02:54 PM
SRTtoZ's Avatar
SRTtoZ
Yep,
Bump that sucker up to about 35psi on each tire and drive around for 20 minutes, the light will go off.
Old Dec 2, 2007 | 03:36 PM
Tire pressure (35 PSI) should always be checked cold. Usually in the morning before diving.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
