Urgent: Help - Driver Window wont Come up
Old Aug 15, 2012 | 12:21 PM
oldschool350z's Avatar
oldschool350z
Default Urgent: Help - Driver Window wont Come up
Well i've owned my z about 1-1/2 years and never had an issue.
Today I rolled my windows down using the keyless entry as i always do, and now my driver side will not roll back up.
Any insight?
Old Aug 15, 2012 | 12:23 PM
Syner's Avatar
Syner
Window motor died. It's a pretty common problem.
EDIT: why is this in the new owners section?
Old Aug 15, 2012 | 12:27 PM
oldschool350z
Damn lol. Is that easy to install and is there a DIY?
Old Aug 15, 2012 | 12:30 PM
oldschool350z
im new and posted in the new owners.
Move it mods.
Old Aug 15, 2012 | 12:31 PM
huyrua's Avatar
huyrua
^^^Yes^^^Yes^^^
Old Aug 15, 2012 | 12:39 PM
BhashaZ's Avatar
BhashaZ
+1
Also, as far as getting it back up:
Originally Posted by jinsei888
punch and hit the side of the door from inside the drivers seat around the area just above the window switch finisher (where the window regulator sits) while you are holding up on the switch, and it will work...you know how our Z's are...****ty window regulators and all hah
(reference: https://my350z.com/forum/showthread.php?p=5670477)
I had mine get stuck in the down position about 4-5 weeks ago and used the suggestion from jinsei888 and it worked out (as it did for the others in the post that tried it). Note that banging on your door panel is a temporary fix to just get your window up. You will still need to replace the window motor. I have to do mine still.
Old Aug 15, 2012 | 01:14 PM
Kingeddie's Avatar
Kingeddie
Did you search????????????? of course not then you would've found or known that the motors go bad all the time and that there is a diy . smh
Old Aug 15, 2012 | 04:10 PM
hellman_x's Avatar
hellman_x
I think you are the first to encounter this problem.
Old Aug 15, 2012 | 06:00 PM
Bmurray350z's Avatar
Bmurray350z
hit your door near the handle while trying to roll it up. temporary fix.
Old Aug 16, 2012 | 05:27 AM
cubs4worldseris's Avatar
cubs4worldseris
Very very common problem with these cars. Search for a diy guide. The repair is not the easiest thing in the world, but it can be done.
Old Aug 16, 2012 | 05:38 AM
pmab9918's Avatar
pmab9918
Mine is acting up again too, if you hold the switch up and close the door at the same time it should go up. Might have to do that a couple times.
Old Aug 16, 2012 | 06:42 AM
Syner's Avatar
Syner
Everytime I go into the maintenance forums to answer a question, there is always someone talking about window motors. If he would have shown even an ounce of effort he wouldn't have made this thread.
Old Aug 17, 2012 | 10:31 AM
whatZheck's Avatar
whatZheck
Saran wrap and duct tape are your friend. You just have to climb over into the passenger seat from now on to get out! Try spraying the duct tape to match the paint on the car.
lapham3
Oct 7, 2022 03:15 PM
Siqcology
Sep 18, 2019 01:45 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
