Motordyne XYZ pipe question
Old Dec 26, 2020 | 10:45 AM
Arod_562's Avatar
Arod_562
Default Motordyne XYZ pipe question
So does the Motordyne XYZ pipe with the optional resonator replace the stock catalytic converters?? It also says they have a HFC option available but its gotten me confused now lol. So if i get the Motordyne XYZ pipe would i HAVE to replace my stock cats with a resonator or a High flow cat?? I thought Y-pipe was seperate from the catalytic converters?
Old Dec 26, 2020 | 11:30 AM
travlee's Avatar
travlee
Master
Xyz is after the cats,
Old Dec 26, 2020 | 11:38 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Or, as one of the options, you can run XYZ with a cat aft of the Y-junction; BEHIND the cats OR test pipes (in this case MD ART pipes).
Catalyst equipped XYZ may or may not conform in 49 state cars, definitely will not in California.
Old Dec 26, 2020 | 12:26 PM
Arod_562's Avatar
Arod_562
So if i were to get the Motordyne XYZ pipe with HFC that would replace the stock catalytic converter?? Or would my car now have a regular cat and a Highflow cat?? Im like confused on that part because why does XYZ include a high flow cat when i thought the y-pipe was seperate from the stock catalytic converter. So i would have to also take out my stock catalytic converter when installing my XYZ pipe with High flow cats??
Old Dec 26, 2020 | 12:27 PM
Arod_562's Avatar
Arod_562
Sorry im still a noob when it comes to exhausts right now lol
Old Dec 26, 2020 | 12:29 PM
Arod_562's Avatar
Arod_562
so in order to run the XYZ pipe i have to either get one of those options resonator, straight pipe, or High flow-cat?? I cant just buy the XYZ pipe by itself and bolt it on? And i meant to reply to you on my response above but messed up 🤦🏽‍♂️
Old Dec 26, 2020 | 12:43 PM
terrasmak's Avatar
you need one of the 3 options
topnotchg
Jun 11, 2014 03:23 PM
Mike Anthony
Mar 10, 2012 06:48 AM
