Super Strange Misfire 05 DE 350z
Old Jun 8, 2023 | 06:35 PM
Blake_Z33's Avatar
Blake_Z33
Default Super Strange Misfire 05 DE 350z
hello! I wouldn't be posting this if it wasn't my literal last resort but this car is about to make me go insane. I've owned the car for 5 years and been nice to it the whole time, keeping up with its needs.
engine: 150k ish. transmission: 72k
starting about 3 months ago, randomly one day the car began to do random misfires, at the beginning it would throw a p0300 but eventually stopped doing so while progressing to get worse. to explain deeper the misfire occurs most often at idle with AC turned off. with the AC on the rpms rev to 1000 and no longer misfire near as much. the misfire sounds like a ghost cam and is completely random. other symptoms have been car will stall if put in neutral while breaking hard only happened once so far but it was getting off the highway, it will just idle down to its own death. also when revving the engine to exactly 1100-1500 rpms and letting off the gas the car will stay revving for about 2 seconds before slowly returning to idle, and when doing so the idle will bounce. also to add, the misfire intensity seems to change randomly, somedays it'll be okay and the power feels amazing, others it feels terrible and super shaky, and feels like a Honda Fit would beat my *** in a race. now to list mods and things I've tried - also if you made it this far thank you for helping!
  • Modifications
invidia n1 catback, Megan racing test pipes
Z1 short ram intake ported upper & lower manifold, Z1 Plenum Spacer 5/16''-1/2' (verified no leaks & did proper sealing)
75mm throttle body (throttle relearn completely with all accessories off)
Build CD009 put in recently
GTR injectors & walbrol 255
Add W1 Baffled Oil Catch Can V3.3
UpRev Tune 5 maps
  • Things I've tried to fix this pain
replaced all coil packs & spark plugs
Intake leak test (pass I replaced all intake manifold gaskets as well)
Vacuum leak (pass)
Throttle body relearn (pass & done correctly)
Messed with the fuel pump & cleaned injectors fuel system is up to pressure (0.2 injector delay all running equal with AC on and off)
Tried various gas stations (running 93)
passed compression on all cylinders (170-177)
downstream o2 sensors are deleted and the tuner has disabled them upstream are fine.
cleaned all engine grounds + main terminals (14.9V cold start 14.3-14.7 warm)
visually inspected intake valves seemed okay and very clean
confirmed coil pack wires are secure
cleaned cam + crank sensor(s) and checked EVAP & PCV valve
properly cleaned + oiled the intake & cleaned the MAF sensor + swapped MAFs with a buddy just to confirm
disassembled VVT solenoids & cleaned them properly
I've consulted with my tuner & a Nissan master tech, and still have no clue
The last code the car ever threw was a p0011 bank 1 about a month ago, tuner looked into it and didn't see anything wrong with the fuel or timing. haven't seen any cel 1500+ miles since then.
Old Jun 10, 2023 | 03:25 PM
joelle king's Avatar
joelle king
Welcome aboard !
did you check the injectors
Lyleri
May 15, 2022 06:01 PM
MotaBike Mike
Oct 16, 2019 01:00 PM
Dillon Vang
Nov 16, 2017 01:59 PM
Milosis
May 24, 2017 05:07 AM
Zlut
Mar 24, 2015 04:23 PM
