NISMO lowered with Cusco Zero-2's
Old Feb 12, 2008 | 04:34 PM
  #61
trodis's Avatar
trodis
abso-friken-lootly gorgeous.
Perfect, dont touch a single thing.
Old Feb 12, 2008 | 04:52 PM
  #62
Ataru074's Avatar
Ataru074
Originally Posted by Z1 Performance
NISMO has a completely different shock and completely different spring. The car is still a Z, and a Z with Cusco coilovers has a certain sweet spot. You can't compare variables from one setup to another, such as spring rate, etc. Once you change the damper, everything changes and all relationships go pretty much out the window.
I have no idea on the clearance of those sorry, I've never done it
I agree, I'm for coilovers.. just saying that the nismo setup is damn good. way better than a stock Z.. I'm only upset they don't offer an R-tune setup because who knows the car better than who build/rebuild it for racing?
for spring rates / dampening I partially agree... for my experience the dampening must be driven by the spring rates.. of corse a "not enough" dampening will result in a kangaroo car and too much will allow you to lift the wheels from the ground, but springs are still the first part of the equation. a car sits on springs. not on dampers.
if you use the same mounts for springs is apple with apple... same leverage, same forces involved... dampening play a MAJOR role when you need to stop the spring movement.. compression, rebound, hi freq, lo freq and the hard part is mate the spring with the right damper. (than also sway bars play a good part into this equations and must be mated with the whole suspension assembly).
cusco is a reputable company. so it's pretty safe.
btw.. I'll try to have as much track time as I can before switching to coilovers... so I'll compare the times
Old Feb 12, 2008 | 06:29 PM
  #63
VENOMSZ's Avatar
VENOMSZ
Looks good
Old Feb 12, 2008 | 06:47 PM
  #64
pacfwu's Avatar
pacfwu
Good. It'd be nice to hear an intelligent review from someone that can make an honest comparison instead of my "Seems to work alright for me" answer.
Old Feb 13, 2008 | 04:20 AM
  #65
Ataru074's Avatar
Ataru074
I'll try.. they just opened a new road track here and it's quite technical with an excellent surface... I expect to learn the track in a couple of weekend... at that point.. grab new tires (again Re050a) and put new suspensions... if after a couple of weekends, finding the right dampening, I can go faster... it's ok, otherwise... nismo suspension are better than what I think.
Matteo
Old Feb 24, 2008 | 09:51 PM
  #66
Nismo 78's Avatar
Nismo 78
Pac, your nismo is bad azz!!! I can't wait to see it in person. Love the rake sits perfect.
Old Feb 24, 2008 | 09:56 PM
  #67
black06z's Avatar
black06z
That's a perfect drop. Gotta get some shine on them tires though.
Old Mar 6, 2008 | 09:08 PM
  #68
ladyzed's Avatar
ladyzed
Man do I ever love the front end of the Nismo Z's. I want this front end bad, along with the 2006 HID bi-x's
Old Mar 7, 2008 | 10:19 AM
  #69
918 Z's Avatar
918 Z
maybe put the balance towards the rear as nismo does is wiser?
I had to bring mine to the track (she had only 800 miles... ) and the stock suspension works great... just a little bit too much of body roll thinking about R comp tires. but DAMN!!!! it's so easy, so neutral (acceptable light understeer in tighter corner entry.. but makes the car more predictable for not so experienced drivers) really easy to manage in corner exit... (especially leaving a nice of couple black stripes)... the only thing I don't like is the vlsd.. as usual.
btw I wasn't pushing the engine hard.. just hard in the corners.
hey Z1.. do you think that a set of volk re30 18*9.5 +22 all corners with 275/40 toyo R888 will clear? (mainly on front fenders).
i currently run 17x9 +24 with 275/40 tires. its a great setup and it fits nicely. Sport compact car runs their project z with 18x9.5 +42 bbs wheels with a 12mm spacer on the front and a 25mm spacer on the rear. they run 275/40 g-force kd tires. the rears fit just fine and the fronts tuck in nicely. it rubs the control arms just slightly under certain conditions but nothing that woiuld destroy the tire or disrupt the car. sitting level and going straight it doesnt rub. its a truely beautiful setup plus you can rotate tires. and the handling is definitely improved.
Old Mar 9, 2008 | 06:43 PM
  #70
ckp's Avatar
ckp
Hey bro it is me Chirag from portland, who helped set up the meet yesterday in Portland, and I am the guy who had the 07 G35s, blueslate. you are right, the drop on your nismo is bad ***! its so much better then just stock! black the windows and I think you car is perfect!
*Updated pics on page 3*
Well, some jackass had to be the first to do it. I just pulled it into the maintenance shop at work and did it myself last night. So it still needs to be aligned. It hasn't been the best weather here and the car is dirty as hell. I'll post up some better pics when we get a nice day and I can wash it up good and proper.
Thanks to Adam at Z1 for taking care of me.
Old Mar 9, 2008 | 07:51 PM
  #71
350zDex's Avatar
350zDex
NIce perfect drop car looks hottt!!!
Old Mar 18, 2008 | 10:15 AM
  #72
pacfwu's Avatar
pacfwu
Thanks man. I just got my clear reflectors and Nismo intakes installed over the weekend. Unfortunately my carbon fiber b-pillars are backordered so I most likely won't have them before GG. Hope to see you there.
Old Jan 29, 2009 | 08:40 PM
  #73
KingBaby's Avatar
KingBaby
Hardest Setting
did you ever get spacer???????
Old Jan 30, 2009 | 06:24 AM
  #74
pacfwu's Avatar
pacfwu
No, I haven't gotten spacers yet. If I ran spacers, I'd probably go with extended studs instead of the ones that have studs built in, and I've just not felt like having that expense. The car actually looks fine without spacers, it's not that super-flush and rolled rears kindof good, but it's fine. I also plan on changing the rear tire size to a 275 and I think that'll look just fine without a spacer.
Old Jan 30, 2009 | 10:52 AM
  #75
white323nismo's Avatar
white323nismo
looks great
Old Jan 30, 2009 | 11:09 AM
  #76
pacfwu's Avatar
pacfwu
Thanks.
I need to do some updated pics one of these days with stuff I've put on it since it's been lowered and I started this thread. It's now got clear reflectors, nismo b-pillar garnish, red lugs, and AAM single exhaust. I've just been too lazy to take pics and do a dedicated thread for it.
Old Jan 30, 2009 | 04:24 PM
  #77
NA&CH's Avatar
NA&CH
get some new pics up meng
Chris
Old Jan 30, 2009 | 04:50 PM
  #78
shawn_david75's Avatar
shawn_david75
I was on the fence about buying my Nismo, it was pacfwu's pics of his on coilovers that made me get it.
Old Jan 30, 2009 | 05:50 PM
  #79
KingBaby's Avatar
KingBaby
Hardest Setting
someone needs to cut a referral check...
Old Jan 30, 2009 | 05:55 PM
  #80
godzilah's Avatar
godzilah
lower!!!!!
