second jackass lowering the nismo
Old Apr 13, 2008 | 02:52 PM
  #61
Sensi09's Avatar
Sensi09
Works Concepts
Originally Posted by zpeedDemon
This should be a hard choice if I were to choose between a Black Nismo Z or a New 370Z.
It might be heresy to some, but I think I'd get a 370Z. Maybe a 2nd year, track model 370Z.
Old Apr 13, 2008 | 03:21 PM
  #62
iheartmyz's Avatar
iheartmyz
noob here...when are the 370z's coming out??
Old Apr 13, 2008 | 04:53 PM
  #63
Ataru074's Avatar
Ataru074
completely agree... especially if it's true that the weight will be reduced. I hope in a 3000 with 350+ hp 8000rpm engine
Old Apr 13, 2008 | 08:50 PM
  #64
zpeedDemon's Avatar
zpeedDemon
i doubt it will be a 350 Hp engine more like 330 Hp
Old Apr 14, 2008 | 02:20 AM
  #65
cuda510's Avatar
cuda510
Stock is 3.5. https://my350z.com/forum/engine-and-drivetrain/301451-4-083-gears-final-drive-installed.html
Yeah it never stops. With your Ohlins, you certainly set the bar high. I think I recommended those to you before, so it's cool that you picked them up.
For myself though, I don't always need the best, and would settle for the good "bang for the buck" products.
On my short list, are 3.9s, a JWT flywheel, an exhaust and the technosquare reflash. I'm up in the air about suspension.
What is the GT LSD and who makes a coppermix disc?
I just like good deals, and I got a great deal on the Ohlins. But, since i moved on from my 240sx, i decided i will put better quality on this $40k car then I did on my 240sx.
GT LSD and the coppermix are all NISMO parts.
below is directly off nismo.co.jp under the specs of the Nismo 380RS-Competition
Deaf メカニカルLSD(GT LSD) Mechanical LSD (GT LSD) クラッチ
Clutch 強化クラッチ(スーパーカッパーミックス) Strengthen clutch (SUPAKAPPAMIKKUSU) <supercoppermix
Old Apr 14, 2008 | 03:26 AM
  #66
Ataru074's Avatar
Ataru074
ok, I'm really interested in a couple of things... how your wheels fits the car (do you have any rubbing issue with the +22 and +18 offset?) a pic or two from the side will be nice!
and where the hell and how much for that clutch/flywheel
Matteo
Old Apr 14, 2008 | 06:36 AM
  #67
pacfwu's Avatar
pacfwu
It's about $1800 for that clutch/flywheel (but I don't know if it works on '07 and newer models):
http://www.japanparts.com/db/partsli...aker=2&volkey=
Old Apr 14, 2008 | 12:39 PM
  #68
Sensi09's Avatar
Sensi09
Works Concepts
Are these Nismo parts different from the Nismo R-tune parts?
http://www.thenismoshop.com/ikorb.ph...product_id=326
http://www.thenismoshop.com/ikorb.ph...&product_id=17
From all accounts, that Nismo LSD does not work well on the street and is a more track oriented LSD.
Nismo doesn't make a flywheel fitment for the '07+ yet, but their flywheel should weigh in at 21lbs. The JWT flywheel in the meantime weighs 14lbs, is still streetable and cheaper to boot.
Old Apr 14, 2008 | 12:53 PM
  #69
pacfwu's Avatar
pacfwu
Do you mean are the parts cuda posted the same as the R-tune parts?
The limited slip should be the same as the R-tune, but the R-tune clutch is not the same as the Super Coppermix Twin. The R-tune clutch is available in Japan. They just have a second clutch option available to them.
Old Apr 14, 2008 | 12:57 PM
  #70
Sensi09's Avatar
Sensi09
Works Concepts
I don't know actually. That's what I was wondering.
Old Apr 14, 2008 | 02:12 PM
  #71
cuda510's Avatar
cuda510
Matteo
I am actually on deployment right now, but when I get home in a month or so I will definately post some pics! You shouldnt have any rubbing issues unless your run an enormous tire like a 295.
BTW, I like track oriented parts!
Old May 2, 2008 | 05:47 PM
  #72
NISMOFO's Avatar
NISMOFO
Is the nismo Z or suspension any lower than a stock Z? What about it vs an S-tune suspension? Any differences? I'm interested in buying a used Nismo suspension off someone, but want to learn about it first.
I posted this same question in another suspension related thread. Just looking for some info w/o really wanting to start a whole new thread.
nanotech
Oct 2, 2015 05:02 AM
