Goodbye rear wiper...
Old Oct 17, 2008 | 11:26 AM
shawn_david75's Avatar
shawn_david75
Default Goodbye rear wiper...
I got rid of that damn rear wiper. I filled the holes with rubber stoppers:
SO much better!
Old Oct 17, 2008 | 11:32 AM
only350z's Avatar
only350z
I kinda like my rear wiper... =(
But its clean..
Old Oct 17, 2008 | 01:45 PM
Joe@Sage's Avatar
Joe@Sage
where did you get the stoppers looks good.
Old Oct 17, 2008 | 02:43 PM
shawn_david75
I got the rubber stoppers at Home Depot. The top one is 1", and had to be cut in half to sit flush. The bottom is 1 & 1/8", and fit in perfectly. The stoppers cost about $2 for both.
Old Oct 17, 2008 | 02:47 PM
Sergio8A's Avatar
Sergio8A
u should paint it PPW! My 2 Cents!
Old Oct 17, 2008 | 02:53 PM
shawn_david75
They are made of RUBBER. The paint would crack.
Old Oct 17, 2008 | 02:58 PM
lgear080's Avatar
lgear080
there are paints which will work. Can you specify an item # off the HD receipt. I have the wiper arm deleted perfectly, but my windshield needs a better plug. Yours looks pro.
What department if you haven't got a number.
Thanks!
Old Oct 17, 2008 | 03:01 PM
shawn_david75
I went to the aisle with all the drawers full of different nuts and bolts.
Old Oct 17, 2008 | 03:11 PM
McGuckin's Avatar
McGuckin
For the lower one you could have used a sink plug which could be painted. It looks a lot better imo. There is a DIY for wiper delete. I do like the the top rubber to match the tint. Good job.
Old Oct 17, 2008 | 03:19 PM
shawn_david75
I considered the sink plug, but the rubber stopper has a lower profile and to me looks better.
Old Oct 17, 2008 | 03:30 PM
WTX350Z's Avatar
WTX350Z
looks good, I've often considered this mod. as I see the rear wiper as useless.
Old Oct 17, 2008 | 04:31 PM
SniperHunter's Avatar
SniperHunter
Have a favor to ask...can you take all of the parts you removed and tell me what they weighed? I'd like to remove mine for both aesthetic and weight reasons. =)
I'm assuming you removed the motor, as well?
Old Oct 17, 2008 | 04:37 PM
tranceformer95's Avatar
tranceformer95
You're serious about the weight savings?
Anyways, I've done it on my Z already. I just put them on a bathroom scale, not super accurate for small amounts but...
Wiper + wiper arm = ~1 lb.
motor = ~2 lb.
Old Oct 20, 2008 | 08:50 AM
SniperHunter
Bah. Nevermind then. Not worth the trouble. I was hoping for something closer to 10lbs. Thanks, though.
Old Oct 20, 2008 | 10:27 AM
tranceformer95
It's definitely worth it if you want to make the rear look clean.
Old Oct 20, 2008 | 10:38 AM
RobH_350z's Avatar
RobH_350z
i should do this cause ever since some dumb b**ch at my
school broke mine.. it doesnt work right... /=
