new suspension for the nismo
Old Jun 17, 2009 | 08:21 PM
black07nismo's Avatar
black07nismo
Originally Posted by lgear080
Awesome... Now respond to my questions in my R35 bbk upgrade thread or pm me.
I want answers.
i would send you the info if i had it on me. i am currently in bahrain until october. the info is in my car with the brake reciept. i can say that i did talk directly with brembo. i got the number off the brembo websight. i had a pretty long conversation with them. in the end they hooked me up with the front and rear monoblock caliper setup. they said that it would be better than the performance of the GTR brake setup.
i like the idea of putting the GTR brakes on a 350z for the looks. when it comes to anything safety related on a car i am very cautious when trying to make things work. the brakes are very important. if you do get them installed they will be mounted with brackets that are not tested in any way. and modifying the other parts of the suspension or hub could cause unwanted or premature wear of the components, even possible failure.
another thing they mentioned to me was that if you changed out the front brakes you would have to change the rear also, or the bias would be all messed up. so putting front 6 piston brakes on would make it required to install a 4 piston setup anyway.
it was just way more cost effective to use the kit i bought.
sorry i cant help more at the time. i would if i had the info with me.
Old Jun 18, 2009 | 02:08 PM
lgear080's Avatar
lgear080
So... It's a good thing that I bought the fronts and rears... Well enough.
When you get back... Pm me.
Old Jul 13, 2009 | 03:20 PM
eddiebrock71's Avatar
eddiebrock71
Originally Posted by black07nismo
the nismo is much more than suspension pieces.
the body kit pieces alone are over 6500 dollars. the body dampers and frame welding is the more important part of this car. by improving on the sway bars and coilovers isnt hurting the nismo. just making it a better handling nismo. same thing with the rims and brakes. the wider front and rear rims and increased brake size will help make the car better.
the nismo really isnt worth anything more than a regular z in dollar value anyway. it has lost so much retail value since i purchased it. sticker price was close to 40000 now it is down under 30000 for a new one and around 27000 for a used one.
every car can be improved on, my brother has a porsche GT3 and he has even put money into it to improve on it.
Car manufacturers dont put the best they can on the car. If companies like brembo put the best system on factory cars they would loose a lot of money in aftermarket sales.
the same is true with the nismo, sure it is better than a stock z but it isnt the best you can do, its an improvement that the customer is willing to pay for.
most people wouldnt spend 60000 on a nismo, even if the suspension, brakes, rims and tires, exhuast and computer tuning were already done. it would just seem crazy when you can get a bmw or something nicer for that price. but as you notice on this forum, there are a lot of people who are willing to spend 40000 on the car and than do that much money in upgrades if not more.
the body kit is the most expensive if you like it.... But the varis pieces are cheaper, and would do the same thing pretty much.
The welded seams is the most crucial part. And actually if you know a good welder, and take off some body panels you can have it done. Not sure on price, but sure you could do it for less then $1500.
The NISMO z rear wheels are too heavy.
With the exception of the welding and body kit, since you put on new wheels, all the other nismo parts can be purchased. Most people I know that have NISMOs hate the fender gap, and lower the car anyways. It sits higher then a stock z.
So like someone commented on earlier, why buy it if you change all the performance upgrades.. You really paid a premium just for seam welding, and the body kit. But since you got it for just a little more then a base model, its a good.
But good luck with the mods, should be a sweet ride. post some pics when you get home..
good luck overseas.
Old Jul 14, 2009 | 10:09 AM
reserved's Avatar
reserved
It's what I was recommended by my installer, the stock suspension is ok but still has a lot of play. I only drive my Nismo for fun and on the track. The stock suspension is not really enough for the track.
Who does the installs on your car? (I live in the same area)
Think I remember seeing pics of your car.
Any track visits in mind when you get back home?????
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
