Question about Camber
Old Jul 12, 2009 | 10:31 PM
xpertool's Avatar
xpertool
Default Question about Camber
My Nismo 350Z in its stock form has a positive camber. I know this because my tires are wearing from outside on all four corners. Now I want to know if stock 350Z needs new front A-arm and rear camber kit to change the camber setting or can STOCK camber setting be changed without the camber kit.
Old Jul 12, 2009 | 11:00 PM
350Zdj's Avatar
350Zdj
you can still change the camber but only to some extent. you can correct the problem with your stock A-arms.
and also, RTFM heheh!
Old Jul 12, 2009 | 11:03 PM
Nizmo0395's Avatar
Nizmo0395
These cars are set up with neg. camber. after looking in my manual front suspension you will need to put a system that is adjustable.Caster camber kingpin inclination is not adjustable. (Decimal degree). Camber minimum -1.33 nominal -0.58 maximum + 0.17. Caster minimum 7.42 nominal 8.17 maximum 8.92. Kingpin inclination minimum 4.33 nominal 5.08 maximum 5.83. Total too-in minimum 0 nominal .04 maximum .08.
Rear suspension is adjustable from bolt in front of lower link. Toe from bolt in rear lower link. Camber rear in decimals minimum -2.08 nominal -1.58 maximum -1.08. Total toe-in minimum .043 nominal .075 maximum .106
Old Jul 16, 2009 | 06:01 PM
Nizmo0395's Avatar
Nizmo0395
^^^^^^ info from service manual volume 2 section F (fsu,rsu) hope that helped.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
