Traction control issue
Old Dec 20, 2009 | 09:21 AM
rnalecz's Avatar
rnalecz
Question Traction control issue
Just got new rear tires, kumho spt 275/30/R19 but still have the stock potenza on the front with 6/30sec left. I noticed traction control randomly kicking in, and aggressively too (completely shutting power off), not like it did before. I was coming off a turn ramp connecting two highways, doing around 80 what i normally do, but it felt weird and of course right after the ramp was done and coming to the straight away, traction control randomly kicked in but for a fraction of a second. This is not normal compared to the old stock tires I had. The old tires did have a bad tire ware pattern, and i never had my alignment done, or could it be a need of a ecu reset? Without traction control on, it runs great. So far 100 miles done.
Old Dec 20, 2009 | 09:27 AM
NISMO_558's Avatar
NISMO_558
Turn the traction control off then
Old Dec 20, 2009 | 09:45 AM
Lakeside's Avatar
Lakeside
Have the alignment checked at your dealer. There is a thread if you search of Nismo's having a slight alignment issue. Mine was fine. I'm not familar with the tires you are using. Post up a pic of the tread design....
If your a confident driver aka one with track experience or mountain run experience with Z's then I recommend turning the traction control off. If I am driving agressively I always have mine off.
Also allow sometime for the new tires to break in.
edit: Also take into consideration the colder temps. The tires just may not be gripping due to tire & surface temps.
Zim
Old Dec 20, 2009 | 03:01 PM
350z 6spd's Avatar
350z 6spd
My guess would be, because the overall diameter of the 275/30/19 you put on is smaller than (or too close to being smaller than) the overall diameter of the front 245/40/18, the traction control is thinking the rear wheel is spinning faster than it should be.
Old Dec 22, 2009 | 05:03 AM
NISMO462's Avatar
NISMO462
+1
The stock rear tire is a 35....a 30 tire is too short.
Old Dec 22, 2009 | 06:17 AM
Blu Hvn's Avatar
Blu Hvn
I had new tires (Hankook) mounted this summer and I took them on a break-in drive. I also had some slippage and the light came on the first few miles. After that, no problems.
Like someone said, break them in first.
Old Dec 22, 2009 | 06:42 AM
LuciaPwNs's Avatar
LuciaPwNs
Thats like trying to cheat death when you turn it off!!!!
sherm
Apr 11, 2020 05:21 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
