KingBaby's Nissan Nismo #0191 'Lin'da'
Old Apr 10, 2011 | 12:55 PM
  #261
Kcee91's Avatar
Kcee91
How's your new CAI's going? Thinking of Stillen Gen 3's? How are the injen's?
Old Apr 11, 2011 | 08:04 AM
  #262
Nismo1534's Avatar
Nismo1534
Injen's R&D is WAY better than Stillen's. I have had both versions on my car and I can tell you that Stillen's design sucks. Just look at the install instructions for both and compare. Also, the black tubing option for the Injens looks way classier compared to the chrome Stillens.
On a side note - I am also running Injen's hydroshields, which are absolutely amazing. I have run the intakes for a few thousand miles and the filters still look brand new. No more worrying about dirt and debris getting wedged between the fins of the filter. This is especially true for the Nismo, where the bottom of the filters are directly exposed to the outside elements. My Stillen filters got really, really dirty pretty fast and took a long time clean, when I was not utilizing the hydroshields. Plus, they are pretty damn good at repelling water for peace of mind.
Old Apr 11, 2011 | 09:10 AM
  #263
jerseystyle's Avatar
jerseystyle
Old Apr 11, 2011 | 11:16 AM
  #264
Kcee91's Avatar
Kcee91
Cool, I've heard great reviews from both the Stillen 3's and the Injen's. I'm going to keep searching, but by the looks of it, I might go Injen!
Old Apr 11, 2011 | 12:28 PM
  #265
brandon3434's Avatar
brandon3434
I like my stillens...They made some good power! I like the injens tho too...They look very similar! I wouldn't go as far as saying Injen's R&D is WAY better Stillens...I'd say they both are great products, both make a good amount of power. (They're def the two best intakes out there for the HR in my opinion.)
Old Apr 11, 2011 | 12:46 PM
  #266
Kcee91's Avatar
Kcee91
@King and Brandon: Do you have any dyno chart videos or pics? Just wondering because CAI's is going to be the next mod.
Old Apr 11, 2011 | 12:57 PM
  #267
brandon3434
No, I personally do not. Either way, they are both great!
Old Apr 11, 2011 | 04:59 PM
  #268
KingBaby's Avatar
KingBaby
Hardest Setting
Agreed they both will pull in higher density air which is always a plus!
From using my scan gauge I've noticed a 1-2 degree difference at idle and a 3-4 degree difference at speed...
This is just from memory so you can disregard it as hogwash!
I haven't driven my car in like 5 days...
Old Apr 12, 2011 | 03:52 PM
  #269
Nismo1534's Avatar
Nismo1534
With the Stillen intakes, the entire system is secured only by the throttle-body and a small strap that you have to somehow mount by drilling some holes and getting really clever. The straps only hold the intakes so well, and the intake tubes can easily move around. The system did not feel securely mounted at all. Also, you have to cut the horn wires, extend them, and, once again, get clever with where to mount them. I am very **** with mods and this was very annoying. Plus you only get three short pages of instructions and are left winging a lot of the install. The chrome tubing is VERY EASY to scratch and shows all defects. To be honest, it sort of looks cheap.
The Injen intakes, on the other hand, come with a lot more accessories to make the installation great! This includes a custom horn bracket to mount in the stock location (no cutting and extending wires) and a nice bracket that attaches right before the filters that you bolt to the top part of your bumper where those plastic clips hold your bumper on (see illustrations below). Then you get seven full pages of instructions to help you along the way. The 90 degree rubber tubing that passes through the core support is also a great addition, as it allows for better adjustment and flexes however you need it to. The black-colored tubing option is very sleek and looks more "professional" if that makes any sense.
And I cannot stress enough how awesome it is utilizing the Hydrofilters to keep water and debris out of the actual filters. I'll never go back to an exposed filter.
Compare what comes with each kit:
Some installed shots (Note the mounting differences):
(Stillen)
(Injen)
My personal installs:
(Stillen)
(Injen)
Hydroshield:
Old Apr 12, 2011 | 04:24 PM
  #270
Kcee91's Avatar
Kcee91
With the Stillen intakes, the entire system is secured only by the throttle-body and a small strap that you have to somehow mount by drilling some holes and getting really clever. The straps only hold the intakes so well, and the intake tubes can easily move around. The system did not feel securely mounted at all. Also, you have to cut the horn wires, extend them, and, once again, get clever with where to mount them. I am very **** with mods and this was very annoying. Plus you only get a few pages of instructions and are left winging a lot of the install. The chrome tubing is VERY EASY to scratch and shows all defects. To be honest, it sort of looks cheap.
The Injen intakes, on the other hand, come with a lot more accessories to make the installation great! This includes a custom horn bracket to mount in the stock location (no cutting and extending wires) and a nice bracket that attaches right before the filters that you bolt to the top part of your bumper where those plastic clips hold your bumper on (see illustrations below). Then you get 16+ pages of instructions to help you along the way. The 90 degree rubber tubing that passes through the core support is also a great addition, as it allows for better adjustment and flexes however you need it to. The black-colored tubing option is very sleek and looks more "professional" if that makes any sense.
(Stillen)
(Injen)
(Stillen)
(Injen)
Hydroshield:
Thanks for the info brother! Also, I found out why our transmission and flywheel sound really noisy along with the fly wheel chatter we have been encountering. The fact is that it is a Nismo and an informant told me that our cars have an upgraded flywheel and pressure plate from the factory. Just wanted to put that out there.
Old Apr 12, 2011 | 05:14 PM
  #271
jerseystyle
Makes me want to buy the injens now!
Old Apr 12, 2011 | 05:42 PM
  #272
Kcee91's Avatar
Kcee91
+1 on the Injen's!
Old Apr 12, 2011 | 05:44 PM
  #273
Nismo1534's Avatar
Nismo1534
Hey, sorry everyone for the intense thread jack!! KingBaby - Let me know if you want me to delete all intake post(s). I made the appropriate thread in the VQ35HR section
Old Apr 12, 2011 | 05:53 PM
  #274
brandon3434
Whoever told you that information is wrong sadly...the nismo transmission is exactly the same as any HR transmission...the simple reasoning is that the stock flywheel is light which is the reasoning behind the chatter/noise...so he is right about that much. but yea our flywheels are the same as the other HR z's...
Old Apr 12, 2011 | 05:56 PM
  #275
KingBaby's Avatar
KingBaby
Hardest Setting
You can leave it here man great info and pics!
Thanks
Old Apr 12, 2011 | 05:58 PM
  #276
Kcee91's Avatar
Kcee91
I was hoping we got an upgrade at the factory! grrr. lol
Old Apr 12, 2011 | 06:13 PM
  #277
Lakeside's Avatar
Lakeside
Injen>Stillen
I personally would save CAI's for the 2nd to last NA Mod. Right before an UpRev tune!
Save your money for HFC's or Test pipes. Biggest bang for the buck mod. Followed by an exhaust system. The intakes are more for looks IMHO! K&N drop-ins with the stock airbox's is quite functional. I went that route for awhile. It's really not worth the 3-5 whp gain that you get from the CAI's IMHO. It's more show, then go!..
Zim
Old Apr 13, 2011 | 09:35 AM
  #278
musubi's Avatar
musubi
Wow, never knew that about the Stillen and Injen intakes. I thought about getting an intake for a bit. Now I'm focusing on saving up for the Nismo exhaust. Just love the sound.
KingBaby, so what's next for Lin'da?
Old Apr 13, 2011 | 09:46 AM
  #279
brandon3434
Hmmm, so anyone know the power differences between the stillen vs injens? I had to zip tie my stillens to get them to stop rattling in like 6 spots, which was annoying...other than that, they fit fine I guess...and make some decent power for intakes...
Old Apr 13, 2011 | 11:54 AM
  #280
Nismo1534's Avatar
Nismo1534
They are tubes with filters on the ends - they make the same power, trust me on this. I ran them both and they were so similar, my tune did not even show a difference.
