Brandon3434's 350z Nismo #0277
Old Dec 12, 2011 | 07:36 PM
  #321
SE5spd's Avatar
SE5spd
almost $1000.00!!
Old Dec 12, 2011 | 11:34 PM
  #322
nismofreak1208's Avatar
nismofreak1208
congrats bro!
Old Dec 13, 2011 | 04:55 AM
  #323
jerseystyle's Avatar
jerseystyle
Originally Posted by SE5spd
almost $1000.00!!
The Stillen bar is only $315
Old Dec 15, 2011 | 08:10 AM
  #324
brandon3434's Avatar
brandon3434
Yesterday, I went to ZSpeedPerformance to help Joe test fit some stuff on the HR/Nismo for some of his new parts he will be selling. For my time spent, he hooked me up with his zspeed aluminum undershroud. Such an awesome part! I'm gonna love being able to do 5 minute oil changes now!!!
Here are some pics:
MUST CLEAN MY Z!!!
Old Dec 15, 2011 | 10:58 AM
  #325
KingBaby's Avatar
KingBaby
Hardest Setting
Sleek....congrats again!
Old Dec 15, 2011 | 01:12 PM
  #326
nismofreak1208
Btw, the stillen one....FITS HORRIBLY.....and i had issues on my end returning it since i bought it new when deployed. So instead of emailing back and forth over and over, i gave up and gave it away to my buddy who had to use a C-clamp to bend one of the support arms to be able to bolt down both sides flush onto the support bars. So yea, buy at ur own risk, i've had 50/50 luck with them on most of my orders
Old Dec 15, 2011 | 04:20 PM
  #327
fhumphrey04's Avatar
fhumphrey04
Here are some pics:
MUST CLEAN MY Z!!!
This is awesome, I dont know why we didn't have a little plastic flap like that- it would make oil changes so much easier!
Also should help protect your oil pan a bit more than the plastic eh?
Old Dec 15, 2011 | 05:43 PM
  #328
brandon3434
Also, something else Joe @ Z Speed Performance had for my z, was a Wilwood Master Cylinder. Here's why this is nice:
If you have an HR, and you want an aftermarket clutch, then its added pressure will cause your slave cylinder to go out very quick, which will cause you to need a heavy duty slave cylinder to handle the pressure. With the new slave cylinder, the stock master cylinder will not be able to force enough hydraulic fluid to the slave cylinder, which will result in the clutch pedal dropping to the floor or not being able to engage into gear correctly. I was experiencing all of these problems, in this order, so now with the heavy duty master cylinder, it effectively forces enough fluid to my slave cylinder, which results in a perfectly operational clutch pedal.
What a mouth full! (Thats what she said.)
Anyways, also heres a pic:
*EDIT* After owning this for a few months, the z drives perfect. No more of the clutch pedal dropping. It basically feels stock, but its working perfect. My/Joe@ZSpeed's goal was to have a perfectly operational clutch pedal to go along with a heavy duty slave cylinder, that is needed to help compliment an aftermarket flywheel/clutch. If you have issues with your clutch pedal after an aftermarket flywheel/clutch/slave cylinder install, this is the fix!
Old Dec 15, 2011 | 06:49 PM
  #329
jerseystyle
Very nice! Gonna have to keep us posted on how the master cylinder works out! Do a write-up on the install.
Old Dec 15, 2011 | 07:06 PM
  #330
nismofreak1208
Hmmmm, very interesting
Old Dec 15, 2011 | 07:31 PM
  #331
kno's Avatar
kno
very nice dude i love that undershroud!
Old Dec 15, 2011 | 08:47 PM
  #332
KingBaby's Avatar
KingBaby
Hardest Setting
hooked up with quality parts
some pics before you hide her away!
Old Dec 16, 2011 | 08:54 AM
  #333
musubi's Avatar
musubi
Wait a minute, even with the HD slave paired with the JWT setup, you were still having the clutch pedal drop to the floor? And by not being able to engage into the gear, you mean like gear grind?
If that's the case...this CSC setup is a real PITA when going aftermarket. Nissan should've stuck with their previous design.
Old Dec 16, 2011 | 07:54 PM
  #334
SE5spd's Avatar
SE5spd
I dont think so, I think it might be extra protection cause I havent heard of anyone having issues, I have a friend with the JWT combo and HD CSC on his HR Z and hes gone a lot of clutch kicking and launches on DRs without any problems. I do have another friend with a HD CSC on stock clutch and he seems to have a bunch of problems, but he just got the wilwood master so well see what happens.
Old Dec 16, 2011 | 09:31 PM
  #335
370zforme's Avatar
370zforme
Hey Brandon, did you do anything to your headlights? They look darker to me.... I'm considering doing a headlight mod but I was worried that it would look too dark during the day but your look good! Maybe it's just me.
Old Dec 16, 2011 | 10:10 PM
  #336
brandon3434
With our transmissions/engines, things will always be a little different for each car. In my situation, my slave cylinder went out due to the clutch, then with the new hd slave cylinder, i had some play in my clutch due to lack of clutch fluid. With this wilwood master cylinder, it helps force the fluid in, which makes my clutch work correctly. Like I said, its different for each car, but if you have your tranny out doing the clutch, I would research the zspeed slave cylinder for sure. Joe has a thread open in the HR engine section about his slave cylinder, lots of info there...
Yeah, painted them satin black, thats all. Also has orange demon eyes. Oh, and regarding darkness, we have projector lenses, its not the old standard bulb and reflector style headlight...so if you paint the inside of the headlight black, it wont change the light output at all. Wasn't too hard, there is a write up on this forum in the DIY section, I believe...let me know if you can't find it.
Old Dec 16, 2011 | 10:24 PM
  #337
370zforme's Avatar
370zforme
who you mind taking a look at my thread in this section and telling me what you think of the mod? Thanks for the info!
Old Dec 17, 2011 | 09:52 AM
  #338
370zforme's Avatar
370zforme
Oh and Brandon, I was lurking this thread and saw that you wanted a Nismo badge awhile back... My friend's Dad owns the Nissan out here and even though they have stupid techs for the most part, they hooked me up for my new emblems. Would you want me to see what they would charge me for a Nismo emblem for you?
Old Dec 17, 2011 | 09:54 AM
  #339
brandon3434
^^^I'm not sure which mod you're talking about? The headlights mod? or...? Also, yes dude! That would be so awesome, I just haven't bought one yet, because I don't wanna pay 200$ for an emblem lol...
Old Dec 17, 2011 | 12:45 PM
  #340
370zforme's Avatar
370zforme
Here's the mod that i'm talking about : http://www.youtube.com/watch?v=7YnuDb_EKIU
And for the emblem, my guy is out today but when he's in i'll give him a call and see what he can do on the nismo emblem. I think that he charged me around $100 for it but I could be wrong because it was some time ago
