Nismofreak1208's Silver Nismo Z (#1208)
Old Sep 26, 2011 | 11:46 AM
  #161
Lakeside's Avatar
Lakeside
The 255 on a 9.5 rim you would have some stretch but the 285 you wouldn't on a 10.5 rim. I have seen several 285's and it was hardly noticeable.
Old Sep 26, 2011 | 11:48 AM
  #162
Lakeside's Avatar
Lakeside
The last time I had my car lazer aligned after dropping the car another finger width, I ran into Toe issues.... The tech could get the camber where I wanted it, but the SPL long toe bolts were maxed out!... I had to have him grind off some material to get it in spec. I was on the phone with SPL who had the same solution as the tech. I couldn't justify not finishing the job, spending crazy cash on more SPL products, waiting for delivery, scheduling another appointment, paying for install and alignment. = OUCH....!
I would of had to spend 2 grand or more on Mid links, arms etc etc.
Old Sep 26, 2011 | 11:53 AM
  #163
KingBaby's Avatar
KingBaby
Hardest Setting
Makes sense!
Forgot to mention! The wheel is compressed in those shots!
Old Sep 26, 2011 | 12:03 PM
  #164
brandon3434's Avatar
brandon3434
Lakeside, his wheels are 19x9.5 front and 19x11 rear, not 10.5...
Old Sep 26, 2011 | 01:18 PM
  #165
nismofreak1208's Avatar
nismofreak1208
*nod nod* back to school I go
Old Sep 26, 2011 | 01:21 PM
  #166
nismofreak1208
Can't edit posts on phone....but going on lakeside comment, would 285 match the stretch on the front if I ran 255 up there? Or should I go lower with 245/275? I understand my camber will be close to suicide....maybe
Old Sep 26, 2011 | 06:06 PM
  #167
brandon3434
The stretch will be the same yes. Sounds like 245/275 is a good option for you, you will have a conservative stretch and will give you some room for your camber adjustment.
Old Sep 26, 2011 | 06:25 PM
  #168
nismofreak1208
hmm, well looks like i've found the tire sizes now, thank you for the help everyone!
Old Sep 27, 2011 | 07:14 AM
  #169
brandon3434
Pics ASAP!
Old Sep 27, 2011 | 11:27 AM
  #170
nismofreak1208
Lmao, kingbaby is trying to convince me to run 255/285
Old Sep 27, 2011 | 12:37 PM
  #171
Lakeside's Avatar
Lakeside
^^^^ I would!
Old Sep 27, 2011 | 01:03 PM
  #172
brandon3434
^^^I second that...fix it with camber!!! MOAR GRIP...that is unless you have to run -5 degrees of camber...
Old Sep 27, 2011 | 01:29 PM
  #173
nismofreak1208
Lmao I dunno how this is gnawing work if I go that route. It seems to me I can only run ridiculous camber but I don't know much about this so MAYBE -3 all around would work???? Ah, such a dillema im in. Just not too confident on it seeing how much they poke. Is there a way to tell if fitment will be an issue without mounting tires, just using the wheel itself?
Old Sep 27, 2011 | 01:31 PM
  #174
nismofreak1208
I meant to type gonna, not gnawing.
Ill be rocking helps aggressive, usually hip or stance wheels with meaty tires,..................this doesn't seem confusing huh?
Old Sep 27, 2011 | 02:19 PM
  #175
Lakeside's Avatar
Lakeside
-3 is alot. I ran -2.7 and i only got around 6-7kmi out of the tires. I'm now at -1.7 to -1.9
I'd have to check my last lazer align print out.
Old Sep 27, 2011 | 03:29 PM
  #176
KingBaby's Avatar
KingBaby
Hardest Setting
Stop surfing the web on your phone while at school!
I've looked at the pictures constantly and I think with -3 you should be good! That isn't that bad of camber since you don't DD the Nismo! Like I told you on texts msgs that the rear is where Fitment can be problems cause it's only so much pull you can do before your fenders are flared!
Before destroying nice tires, really think you should buy cheap used tires to test fit...
Not to let my ideas out but since my fenders are trimmed and flared and punched already I just need to find a shop who's good at fabrication so I can have a mini GTC car!
<-----crazy
Old Sep 27, 2011 | 03:33 PM
  #177
nismofreak1208
No one sells the sizes I need to test fit here in oahu
Old Sep 27, 2011 | 03:34 PM
  #178
nismofreak1208
Im surfing on break. There's only so much about powerpoint on caterpillar trans and engines and sensors and solenoids that we can take before someone passes out
Old Sep 27, 2011 | 04:02 PM
  #179
jerseystyle's Avatar
jerseystyle
I'm doing the same thing
Old Sep 27, 2011 | 04:12 PM
  #180
KingBaby's Avatar
KingBaby
Hardest Setting
