Nismo wheels
Old Jun 18, 2011 | 07:31 PM
1LowNizmo's Avatar
1LowNizmo
Question Nismo wheels
Hi, I just recently purchased a new set of wheels to replace my nismo wheels and am trying to put my rear 19x10 nismo wheel on the front till I can get spacers for the new wheels I bought and its not fitting and I was wondering why its not fitting? bc ive seen ppl running the 19x10 nismo wheels all around on their nismo and there wasnt any mention of having to mod anything to get em to fit. please help?
Old Jun 18, 2011 | 07:34 PM
omsin523's Avatar
omsin523
There's usually a bolt you have to remove on the front rotors, this is so you don't put the rear wheels on the front by mistake.
Old Jun 18, 2011 | 08:21 PM
Flipntek69's Avatar
Flipntek69
Just remove the bolt and your good to go
Old Jun 18, 2011 | 08:30 PM
jerseystyle's Avatar
jerseystyle
Out of curiosity, why would you buy new wheels that require a spacer
Old Jun 18, 2011 | 08:31 PM
"Not fitting" doesn't mean jack to me. Why is it not fitting?
Tight against the brake calliper?
Will not fit over the brake rotor.
Will not clear the suspension?
Old Jun 18, 2011 | 08:45 PM
jerseystyle
More details please....
Someone else on here put 19" NISMO wheels all the way around and I know he used 20mm spacers. Not sure if they were needed or not
Old Jun 19, 2011 | 01:38 PM
Czarrr's Avatar
Czarrr
It's probably that bolt to prevent putting rear wheels on the fronts.
Old Jun 20, 2011 | 10:23 AM
NZMOWND's Avatar
NZMOWND
umm sorry i just saw this...im running this right now but u need atleast a 10 or maybe 15mm spacer..IT WONT CLEAR without a spacer...im running a 20mm spacer and its close to rubbing, also remove that bolt on there as well
