Nismo #1033
Old Mar 28, 2012 | 09:05 AM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Old Mar 28, 2012 | 09:38 AM
tkuntz's Avatar
tkuntz
keep it up! in for results.
Old Mar 28, 2012 | 09:06 PM
NismoZ#1033's Avatar
NismoZ#1033
Default Update
Got started a little later tonight.The actual "build" has begun so taking it nice and easy.
Removed the plenum,fuel rail and injectors
http://www.flickr.com/photos/75614849@N08/7025797963/http://www.flickr.com/photos/75614849@N08/7025797963/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Removed the dirty stock injectors and installed the new Denso 600cc injectors
http://www.flickr.com/photos/75614849@N08/6879744198/http://www.flickr.com/photos/75614849@N08/6879744198/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Cult and lengthen the oil temp and pressure wires 3.5"
http://www.flickr.com/photos/75614849@N08/6879703736/http://www.flickr.com/photos/75614849@N08/6879703736/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Prep supercharger for install
http://www.flickr.com/photos/75614849@N08/7025845625/http://www.flickr.com/photos/75614849@N08/7025845625/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Too bad this is the front of the supercharger. The other side looks better
http://www.flickr.com/photos/75614849@N08/6879735488/http://www.flickr.com/photos/75614849@N08/6879735488/ by http://www.flickr.com/people/75614849@N08/, on Flickr
That's it for tonight. Just about half way through the instruction manual
Old Mar 28, 2012 | 10:00 PM
bena1916's Avatar
bena1916
As you go through the install I would be interested in what stock parts, that remained, on the car did you have to modify to get the kit to fit. Especially up front around the intercooler piping?
Old Mar 29, 2012 | 09:56 AM
NismoZ#1033
Off the top of my head i think the only stock parts that have to get modified are splicing some wires, trimming a little plastic off of the fan shroud, and drilling some holes into the frame and bumper brace for moutning brakets. So nothing too major.
Old Mar 29, 2012 | 11:15 AM
musubi's Avatar
musubi
In for moar install pics please
Old Mar 29, 2012 | 09:07 PM
NismoZ#1033
Default Update
Continued to chip away at it
Started by triming the bottom right corner of the fan shroud.
http://www.flickr.com/photos/75614849@N08/6882489128/http://www.flickr.com/photos/75614849@N08/6882489128/ by http://www.flickr.com/people/75614849@N08/, on Flickr
After
http://www.flickr.com/photos/75614849@N08/6882489136/http://www.flickr.com/photos/75614849@N08/6882489136/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Mounted the supercharger and the bracket to the block
http://www.flickr.com/photos/75614849@N08/6882489140/http://www.flickr.com/photos/75614849@N08/6882489140/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Reinstalled the alternator, installed the supercharger oil filter on the passenger side frame rail, idiler pully,PS lines, all associated mounting brackets (4)and bolts , and a semi installed PS pump
http://www.flickr.com/photos/75614849@N08/7028591827/http://www.flickr.com/photos/75614849@N08/7028591827/ by http://www.flickr.com/people/75614849@N08/, on Flickr
It was a pretty good night. The only issue that we ran into is that the holes on the bracket that the power steering pump bolt into are tiny bit off. Enough that 1 bolt doesn't thread on. No worries though, just gunna dremel it out ever so slightly. To be honest, everything has been going very smoothly so far. Just look at the instructions, find the,parts,install. Wash,rinse,repeat.
Old Mar 29, 2012 | 11:00 PM
KingBaby's Avatar
KingBaby
Hardest Setting
good to hear your making progress so quickly!
Old Apr 1, 2012 | 11:27 AM
NismoZ#1033
Default Update
Here are some pics from a beautiful Saturday afternoon.
Got the power steering pump to bolt up nicely and installed the PS lines. All this wiring will be tucked away further along in the build.
http://www.flickr.com/photos/75614849@N08/7035887453/http://www.flickr.com/photos/75614849@N08/7035887453/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Installed the idler pulley, tensioner and belt.
http://www.flickr.com/photos/75614849@N08/6889794200/http://www.flickr.com/photos/75614849@N08/6889794200/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Removed the mass dampener and installed the power steering cooler.
http://www.flickr.com/photos/75614849@N08/6889795454/http://www.flickr.com/photos/75614849@N08/6889795454/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Installed the glorious intercooler
http://www.flickr.com/photos/75614849@N08/7035893931/http://www.flickr.com/photos/75614849@N08/7035893931/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Reinstall the crash bar.
http://www.flickr.com/photos/75614849@N08/6889796710/http://www.flickr.com/photos/75614849@N08/6889796710/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Mount the hard lines for sc oil
http://www.flickr.com/photos/75614849@N08/6889797746/http://www.flickr.com/photos/75614849@N08/6889797746/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Install the sc oil cooler
http://www.flickr.com/photos/75614849@N08/7035894713/http://www.flickr.com/photos/75614849@N08/7035894713/ by http://www.flickr.com/people/75614849@N08/, on Flickr
SC oil resevoir
http://www.flickr.com/photos/75614849@N08/7035895887/http://www.flickr.com/photos/75614849@N08/7035895887/ by http://www.flickr.com/people/75614849@N08/, on Flickr
And then mother nature took a crap
http://www.flickr.com/photos/75614849@N08/7035934379/http://www.flickr.com/photos/75614849@N08/7035934379/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Anyways, the clutch, flywheel, and upgraded slave cylinder should be going in tomorrow. I will also be going back to stock catalytic converters for their longevity over high flow cats.
Old Apr 1, 2012 | 11:35 AM
tkuntz's Avatar
tkuntz
is this kit fairly basic by following the "manual" or is it best to get it done by the pros? either way its coming along nicely, cant wait to see the final numbers. wouldn't mind doing this myself but i just don't have the coin for it right now ha.
Old Apr 1, 2012 | 12:00 PM
NismoZ#1033
This is a straight forward install. That being said, it would suck to have to do this in a little detached garage . Working on a lift makes it a lot easier. Me and 2 journeyman mechanics are working on this after working hours. You have to be extremely organized as there are literally hundreds of bolts, fittings, clips packaged in plastic baggies. Also if its just one person going the install , then it will take them quite a while.
Old Apr 1, 2012 | 12:20 PM
tkuntz's Avatar
tkuntz
ha yea i bet it would take some time, but i bet if your meticulous when it comes to your mods and you have a good sense of knowledge of how to do this kind of thing not to mention the tools, i bet you could pull it off.... that being said, i don't know if i would try and pull this off by myself.
Old Apr 1, 2012 | 04:02 PM
NismoZ#1033
Ya you're pretty much right. Just have to care about what your doing. There's been a couples time where we have caught each others mistakes with the install process. Its also pretty fun building something like this.
Old Apr 2, 2012 | 01:53 PM
Nismo1534's Avatar
Nismo1534
I love threads like this....more walk than talk!
Old Apr 2, 2012 | 08:56 PM
NismoZ#1033
Default Progress
Ok so did a few hours of work this evening. Install is going very smoothly and everything is fitting perfectly. Only incident was my hand slipped off a rachet and sliced my finger pretty good rookie mistake. Im pretty stoked about the build now that the shinny bits are going on. M3 hunting in no time
Oil filter relocation. I had to drill three 5/16" holes in the frame to mount the oil filter bracket. Will go with a oem filter.
http://www.flickr.com/photos/75614849@N08/7040944287/http://www.flickr.com/photos/75614849@N08/7040944287/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Reinstall the anti roll bar. It was a tight fit torquing a couple bolts here next to the supercharger.
http://www.flickr.com/photos/75614849@N08/7040945083/http://www.flickr.com/photos/75614849@N08/7040945083/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Lower intercooler piping
http://www.flickr.com/photos/75614849@N08/6894848756/http://www.flickr.com/photos/75614849@N08/6894848756/ by http://www.flickr.com/people/75614849@N08/, on Flickr
K&N air filter and turbosmart blow off valve. I was talking to one of the guys at gtm about recirculating the bov to the intake pipe, but they advised me that the vq35hr doesn't need to have a recirculated setup. Can anyone confirm this? I mean if it doesn't have to then it doesn't have to. I heard gtm switched from a bosch by pass valve to turbosmart bov due to problems with compressor surge.
http://www.flickr.com/photos/75614849@N08/7040946397/http://www.flickr.com/photos/75614849@N08/7040946397/ by http://www.flickr.com/people/75614849@N08/, on Flickr
Installed the intercooler mid pipes
http://www.flickr.com/photos/75614849@N08/6894850040/http://www.flickr.com/photos/75614849@N08/6894850040/ by http://www.flickr.com/people/75614849@N08/, on Flickr
So i guess that the remaining things left is install some new spark plugs (1 step colder) , upper intercooler piping, and the balance of the stock parts. Gotta fill the car with fluids and prime the supercharger oiling system, install stage 3 clutch and flywheel. Then tune of course.
Old Apr 3, 2012 | 03:48 AM
morphiusrt's Avatar
morphiusrt
Looking good!!! I'll be up there next week so we can install mine.... K? lol i wish.
Old Apr 3, 2012 | 06:05 AM
NismoZ#1033
Come on you know you wanna. Just sell a kidney
Old Apr 3, 2012 | 08:33 AM
  #38
morphiusrt's Avatar
morphiusrt
If I could get that much for a kidney I so would do it.
Old Apr 3, 2012 | 09:07 AM
  #39
B_Heebs's Avatar
B_Heebs
Hey! Good to see another local guy doing this! ....Here I thought i was gonna be the only one.. DAMMIT! LOL! I also live in the Edmonton area, finally got my supercharger kit from GTM.. Waiting for Sam to send me the ROM files so i can begin my install. What shop are you doing your install at? Hard to find a good shop in this area, I would like to use them to install my clutch, kind a pain in the a** to do that part without a hoist!
Who are you going to get to tune your car? I'm kind of at a loss on this, I was thinking Lightspeed in Red Deer, but I recently heard a couple horror stories... We should hook up once we get this all together!
Old Apr 3, 2012 | 10:14 AM
  #40
NismoZ#1033
Howdey! Good to see another guy that went with the GTm sc kit. What stage did you get? Im still waiting for my flash cable to come in and to get my tune from gtm. Im pretty sure you can start doing the install with out having your ECU reflashed (provided you have no codes).
Im doing the install at a shop called Savvy Import.
http://www.flickr.com/photos/75614849@N08/7042594971/http://www.flickr.com/photos/75614849@N08/7042594971/ by http://www.flickr.com/people/75614849@N08/, on Flickr
I have delt with them alot over the years. Their work and carftmanship is stellar and extremely professional. Highley reccomend them. Yea and i would hate to have to do this install without a hoist. Not saying that its impossible though.
I was considering lightspeed as well, but the guys at Savvy know a guy locally who seams to know wtf he's doing. If things dont pan out with him, i think ill go to lightspeed. I know they are very experienced with tuning and are a certified Uprev tuner. Either way im going to have the car tuned professionaly, im not going to "learn" how to tune on this car and f*ck it up lol.
And yea for sure meet up once are kits are in and running smoothly
