what i need to install nx
i was planning on buying a nx kit but i know there has to be moer then just getting the kit. it there any fule mods i need or spark plugs ect. just wanted a list of some things that i would need to run a 100 shot safely thanks
Originally posted by ZU L8R
1 step colder plugs, a TPS or WOT switch and maybe a window switch if you have an auto.
you also need the Genx II kit if you're planning to run at the track. It adds the Purge, and Blow Down Tube as well as the fuel safety shutoff.
Window switch is a must or you go Boom in case you hit the limiter
Plugs need to be copper or irridium NO Platinum that'll melt
Depending on the shot you should add higher octane gas at a minimum add NX chemical X nitrous booster
The Blown Down Tube is an NHRA requirement, they won't let you run otherwise. It's purpose is to vent nitrous out the car in case the safety valve pops at 3000 psi, that way you don't sufficate in your car, since pure nitrous won't let you laugh yourself to death
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
