Nitrous Oxide Too soon, jr.
window switch
Old Jan 29, 2005 | 11:16 AM
spdu4ia's Avatar
spdu4ia
Default window switch
does anyone use the msd digital window swich? if so what wire did you tap for your tach signal?
Old Jan 29, 2005 | 11:28 PM
mrtomcat's Avatar
mrtomcat
rpm from the #1 cylinder is pin 62 this at the ECU
Old Jan 30, 2005 | 07:11 AM
spdu4ia's Avatar
spdu4ia
is there a diagram anywere on how to tap pin 62? or what color the wire is?
Old Jan 30, 2005 | 08:50 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Just FYI as well. Program the window switch as 1 cylinder to get a proper rpm reading
Old Jan 30, 2005 | 09:44 AM
weslutes's Avatar
weslutes
I used the green wire off the #6 cylinder
Old Jan 30, 2005 | 12:05 PM
spdu4ia's Avatar
spdu4ia
were is the wire located? and what model number spark plug do i need...
i've heard it is the NGK LFR6A-11 (v-power) or the LFR6AIX-11 (iridium), which one would you recomend?
Old Feb 6, 2005 | 05:51 PM
KYG35's Avatar
KYG35
Where is the ECU and how do you program the window switch for a 1 cylinder? Mine only has an option for 8, 6, and 4.
Old Feb 6, 2005 | 07:20 PM
spdu4ia's Avatar
spdu4ia
nonono. you use the lead wire from the number 1 cylinder.
Old Feb 6, 2005 | 09:37 PM
mrtomcat's Avatar
mrtomcat
fyi this has the pins on the ecu:
http://www.mohdparts.com/emanage/in...nage_wiring.pdf
in terms of plugs go with the LFR6AIX-11 (iridium)
the ECU is located on the drivers side where you usually would find the glove compartment. here's how you get to it:
http://www.technosquareinc.com/350ZECUremoval.htm
Old Feb 7, 2005 | 08:02 AM
spdu4ia's Avatar
spdu4ia
your first link is dead for me.. anyone else have the diagram for the pin location?
Old Feb 7, 2005 | 10:34 AM
mrtomcat's Avatar
mrtomcat
sorry, it was late...this one should work
http://www.mohdparts.com/emanage/ins...age_wiring.pdf
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
