Nitrous Oxide Too soon, jr.
digital window switch wiring
Old Feb 23, 2005 | 09:03 PM
spdu4ia's Avatar
spdu4ia
Default digital window switch wiring
Help... i dont understand were the two output wires (gray/yellow)comming from the window switch goto. in the instructions it says
grey: normaly closed. this wire will remove the ground source at your desired ON rpm, and comlete the ground circuit at the set OFF rpm
yellow: normaly open. this wire will provide a ground source at your desired ON rpm, and remove the ground at the set OFF rpm.
so Yellow=supplies ground Gray=removes ground
so i attatch the ground wire from the nitrous selenoids to the yellow and the gray to a ground?
thanx for the help in advance. i feel dumb because i wired the whole system up and cant figure out this little black box.
Old Feb 24, 2005 | 02:37 PM
Znitro's Avatar
Znitro
Default Re: digital window switch wiring
Ground your solinoids as you would and run your hot wire thru the yellow wire.
350Z_Al
Oct 29, 2020 07:44 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
nanotech
Oct 2, 2015 05:02 AM
