Any Blown Motors With Nitrous?
I ran a 150 whp shot in my car for more than a year and never had problems.Other parts to run this setup were a MSD Window Switch,Step 2 Cold Sparks,Walbro 255 and a Good clutch, i used a ACT and some good AF tuning.I clocked a 12.0 @ 117 with drag radials and my average time with street tires were 12.5's to 12.8's depending on track conditions.Nitrous is not bad.The key to have a succesful NOS equipped car is tuning and have all the necessary supporting parts for safety.
I just blew my engine yesterday..I have 2 step colder plugs.
zex wet kit and I was running 100shot.
The shop told me that the cylonoids must of failed and it caused it
to go lean.. I had it for 1 year and when the engine blew I was on the
highway doing 70mph..
I'll never put nitrous on any other car that I own in the future
That sucs bro. Sucs that your first post on the forum is such a negative one.
Please inform us of the part that fail if possible.
Enjoy ur new engine!!!
Originally Posted by johanna1
Sounds to me you did not have a good tune, and the nitrous was not to blame. Nitrous can be safe as long as you have the right amount of fuel and proper fuel equipment. So how fast did you run with a 200shot? I think I may go with a NX setup.
and put it towards a form of F/I you dont have to refill al the time..
Originally Posted by nissansource
yah a wideband and window switch along with plugs for added protection...
Yes, I didnt plan on making my first post explaining what failed and led to my engine blowing.
The shop that installed it said that the cylonoids failed..
I'm thinking what happened was that I had just filled my bottled and it must of been about 100 degrees that day. I'm thinking that full bottle along with the high temp caused too much pressure on the cylonoids thus causing a leak. I'm not sure how much pressure they can take; maybe someone else can comment on it.
Now I feel that the extra HP just wasnt worth the exposure you put yourself through..
Anyhow.. Good luck if you do go with NO2
if you have weak solenoids, they can't open up under extreme pressure. That is my biggest beef witht eh NOS and Zex kits....wimpy solenoids.
Check out the NX solenoids....freakin' huge!!!
BTW, I've never had a solenoid fail on an NX setup. I had an NOS remote bottle opener (solenoid style) fail on me. What a POS that was. NOS sent me a brand new one, and I ebayed it!!!
