Nitrous Oxide Too soon, jr.
NX location for low profile
Old Aug 15, 2005 | 08:05 AM
first350's Avatar
first350
Default NX location for low profile
I just signed for a '05 enthusiast and will be picking it up this coming weekend!!! I already have a NX wet kit from an old project and am thinking about hooking it up...I haven't seen too many descriptions of ppl's set-up (location of components) and am looking to keep a low profile. (I'm thinking of installing the 10lb tank where the spare tire is-I'll probably only run N20 during track times).
What are things I should know before starting?
*I'm not looking to modify too much, and will probably run a 50 shot at most.
this is what the NX kit has: fuel/N20 solenoids, purge valve, 'arming' switch, purge button, activation button, and all the lines and nozzle, N20 pressure gauage). I'm not planning on running the WOT (wide open throttle) switch...I know to be careful in not activating it until WOT and higher RPM's.
where are common locations for: solenoids, nozzle, activation switch and buttons?
Thanks!!!
Old Aug 15, 2005 | 08:21 AM
first350's Avatar
first350
Also, Is it okay to leave the timing stock...I have the bare bones NX wet kit: it just adds the fuel/N20 when I hit the button.
I'll plan on getting colder spark plugs-anything else?
Old Aug 15, 2005 | 10:10 AM
TheBigShow's Avatar
TheBigShow
there is an optimal conditions timing map that will need reflashed.
Old Aug 16, 2005 | 01:05 PM
QuadCam's Avatar
QuadCam
go with 1 step colder plugs,non platinum too. NGK iridiums come to mind. All is else is fine.
Alot people mount the solenoids under the brake master cylinder. I have also seen them mounted to the back of the intake manifold , near the firewall.
It is really basic to install.
Old Aug 16, 2005 | 05:00 PM
first350's Avatar
first350
what's 'reflashing'...It sounds like getting the ECU modified, is that right? If so, I'd assume I have to find a shop to do it.
thanks!
Old Aug 16, 2005 | 06:18 PM
TheBigShow's Avatar
TheBigShow
technosquare should be able to do it; they are based in ca. i heard about it at altered atmosphere.
Old Aug 18, 2005 | 06:09 AM
first350's Avatar
first350
How easy is it to mount some switches in the middle consol compartment (where the navigation system would go if I had one)?
I'm thinking to put the ON/OFF and purge switches there, and then to find a diffrent more accsible place for the 'GO' button.
also, where are ppl splicing in to get 12V power?
thanks!
Old Aug 18, 2005 | 06:58 AM
raptorbh12's Avatar
raptorbh12
well thats what i wanted but altered atmosphere said it was "impossible" because of the wires and intereference that goes on back there. Then again altered dosnt know what the hell they are talking about so who knows. go for it.
Old Aug 19, 2005 | 06:07 AM
QuadCam's Avatar
QuadCam
Find a car audio shop with an istaller who is knowledgable about wiring and relays. With some creativity, you can use existing switches and buttons to activate, purge, control your nitrous system.
Go james bond style. Here are some suggestions that I know work
Cigarette light = Arm Nitrous
Winshield Sprayer = Purge
Seat Heater = Bottle Heater
My suggestion is to use a single discreet aftermarket switch to toggle these factory buttons between their normal use and their Nitrous use.
Old Aug 24, 2005 | 01:20 PM
defex's Avatar
defex
..that's a whole lotta wiring..
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
