nitrous install directions
ok guys, i know im skilled enough to do this but im used to hondas so not sure exactly how to do it , so can somone please give me really good directions on how to install a zex wet kit. thanks
It is very straight forward.
Not sure about the TPS wire though. I use a microswitch under the gas pedal.
For the fuel tap, try this:
here's the link: http://www.ptpmotorsports.com/fuliad.html
the zex kit is a universal kit. It'll work on 4, 6, or 8 cylinders engines.
Before I go further, is the Zex kit a "wet" kit? If so, the adapter that I posted will work. For all the wet systems, you need to "grab" fuel from somewhere. By using this adapter, you don't have to cut in the stock fuel line.
someone told me itshard to install a nitrous kit on a z cause there is like a certain way to do it. can someone just tell me if there is somthing importnt i need to know
Tochigi_236
Sep 27, 2015 03:40 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
