Nitrous Oxide Too soon, jr.
G35 Dry Zex Install
Old Nov 16, 2005 | 10:10 AM
350Mike's Avatar
350Mike
Default G35 Dry Zex Install
Wow i need help with this dry kit zex #82011. I have no idea where to put the intake and fuel pressure regulator vacuum lines. I know everything else how to wire the tps and all but for the zex system you have 2 vacuum lines that are supposed to raise the fuel pressure to add more fuel while spraying. My question is where do i install these lines where is the fuel pressure regulator. If anyone can give me any info it will help, also if someone can give me a detailed picture guide i will if you would like send you money on paypal. I am that desperate thanks again.
Old Nov 16, 2005 | 03:30 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
well you are in trouble, those kits are made for return fuel systems where you can raise the fuel pressure with vacuum lines, ours is returnless and the vacuum lines wont work,
i would just go ahead and get the wet kit conversion, add some fuel to it and make it much safer, those kits work well on hondas and other cars with return fuel lines but no ours...
hope this could help a bit and let us know if you need some more help
that will only cost you $1000.... thanks
audiblemayhemfl@yahoo.com hehehe im kidding
Old Nov 16, 2005 | 03:56 PM
Absubtle's Avatar
Absubtle
Yeap, returnless fuel system. Just pulse dampers.... The fuel is regulated at fuel tank.
Time for a single wet system.
I hate dry nitrous systems anyway... talk about giving nitrous a bad name.
Absubtle
PA
