Nitrous Oxide Too soon, jr.
Help Needed
Old Jan 22, 2006 | 02:23 PM
chewy_the_legen's Avatar
chewy_the_legen
Default Help Needed
Hey guys some one told me to go ahead n use nos but i have no idea what brand or anything about it. im suppost to race this 1987 5.0 with minor mods i say no more than 300 hp. my cars n 05 n its automatic...yes i know...it costed 19k brand new, 43 miles no bumper or side skirts so thas the reason why... so please help me
Old Jan 24, 2006 | 07:51 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Nitrous isn't something to really jump into lightly, or without much knowledge on. Do a search on here, there have been plenty of informative threads about this topic, but here is a general summary IMO:
Start off with a "gentle" shot of 50hp or so, to get used to how nitrous works on your car. Gradually increase as desired, but remember to not get too power hungry, the motor will not like you for that....
As for kits, a entry level system for the Z would be a single fogger wet kit. This means that you have one nozzle (single fogger) in your intake prior to the throttle body, and that it injects nitrous and fuel (wet) at the same time. One of the nicest kits out there is the NX nitrous kit, found here:
http://performancenissanparts.com/ca...oducts_id=2796
Now, a few things to remember for safety; have it installed by a pro, i can't stess this enough. Also, do not cut into your factory fuel line you may regret it later on, instead we recomend to use a "t" fitting that allows you to tap into the fuel line without any cutting etc... Also, always run at least one-step colder spark plugs, to keep the detonation in check.
Nitrous is perfectly safe as long as you know how to use it.
Old Jan 27, 2006 | 09:04 AM
Old School's Avatar
Old School
Shift_Boost
Couldn't have said it better myself. Nitrous Express (NX) is the only way to go. WHEEL HP ratings, not flywheel, warranty, best design, safest kits. If you do decide to go with nitrous...look up as much info about how to use it. There are quite a few rules to follow when spraying. Just to name a few:
1) Don't spray under 2500-3000 rpms
2) Only spray at WOT (most kits come with a WOT switch)
3) Don't spray more than 15 seconds (nitrous is for short burst, not long hauls)
4) Make sure pressure is between 900-1050psi (too low and you don't get enough nitrous, too high and you too much)
Nitrous is no joke....but once you have the rules down, its the safest, cheapest, best (IMO) form of forced induction. And you retain stock driving characteristics when not on the juice!
Old Jan 27, 2006 | 09:47 AM
cj350's Avatar
cj350
This might help you
http://www.350zmotoring.com/forums/s...300#post496300
sherm
Apr 11, 2020 05:21 PM
