Nitrous Oxide Too soon, jr.
mid-install help!!!!
Old Jun 28, 2006 | 06:46 PM
rico3682's Avatar
rico3682
Default mid-install help!!!!
Hey guys, I have my entire nitrous kit installed, i am just having a tough time figuring out which wires to use for my nitrous controller. i have the dynotune 2 in 1 tps and window switch. which wires on the ecu would i use to hook up to the throttle and rpm? thanks in advance.
-Eric
ps- i will get a ton of pics when its finished. everything is hidden...all the solenoids are under the wiper cowl and the guages/switches are in a panel in the nav cubby. it looks great, very stealth.
Old Jun 28, 2006 | 09:05 PM
Chris Green's Avatar
Chris Green
I am wondering the same thing......lol
Old Jun 28, 2006 | 11:22 PM
killerlexus's Avatar
killerlexus
Banned for Scamming
i ask the same question last month, have yet to get a reply...help..
Old Jun 29, 2006 | 05:24 AM
rico3682's Avatar
rico3682
Help us out!!!
ps- anyone in the sofla area that needs an install, i highly recommend chris green at unforgettable sound and performance. cleanest nitrous install i have ever seen. they really take the time to make sure things are perfect.
Old Jun 29, 2006 | 08:40 AM
rico3682's Avatar
rico3682
We figured it out. Picking the car up now. So excited. I will post the correct pins for RPM and Throttle Signals in case anyone else needs the info. Thanks again Chris!
Old Jun 29, 2006 | 09:05 AM
Nowell's Avatar
Nowell
National Z Club
There is a TPS wire under the throttle body. If you peel back some of the protective shield you should see a white wire, or possibly a white wire with a green stripe depending on year. That should be the 5v TPS source. You can just tap it there.
Old Jun 29, 2006 | 12:24 PM
rico3682's Avatar
rico3682
Thanks Nowell. We tapped the ecu. Pin 52 and pin 60 for rpm and throttle. It is up and running great. It sprays at WOT between 3100-6600 rpms. I will get pics of the entire setup tonight.
Old Jul 26, 2006 | 09:07 AM
first350's Avatar
first350
FYI: I got the '05 service manual to double check and it's the same.
Pin 52 - TPS #1
Pin 60 - cylinder #1
