Nitrous Oxide Too soon, jr.
Good Tips on a Safe Nitrous Install?
Old Aug 19, 2006 | 08:46 AM
woodstock300s's Avatar
woodstock300s
Default Good Tips on a Safe Nitrous Install?
Does anyone have any good tips/pointers/advice on how to install a safe nitrous setup.....ex.-I dont want to blow the car up
Im lookin to get a nx wet kit 75 shot...heater... opener...6mt
Thanks in advance!
Old Aug 19, 2006 | 09:12 AM
first350's Avatar
first350
I have a very similar set-up...get a TPS/window switch and plan ahead for your wiring. Other things to get: fuel pressure saftey switch, 1-2 step colder spark plugs...@ a 75 shot, you won't need a N2O controller.
-peter
Old Aug 19, 2006 | 01:20 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
a utec is a good step towards a safe nitrous install, it will act as a tps switch, a rpm window switch and will retard your timing with any knock,
pm me for a good price on utec and all the NX stuff you need.
pm me with a list of what you are looking for and i will help out. i have had nitrous on a couple VQs myself and know a lot about the install...
thanks
jeremy
Old Aug 19, 2006 | 01:24 PM
Miraclekidjr's Avatar
Miraclekidjr
Now I know who to talk to....thanks, I might come up to Orlando for the install
Old Aug 19, 2006 | 01:29 PM
woodstock300s
a utec is over my budget...is it really needed? if it is then im gonna have to wait on the nitrous. i wanted to do just a simple setup with a 75 shot
Old Aug 19, 2006 | 02:08 PM
Audible Mayhem
My350z
sorry, you asked "safe" it would be about the safest...!!!!
to set up a nitrous kit safe it will end up costing you about a 800 for kit, TPS switch and Window rpm switch...
that would be a safe start, you dont really want to cut any corners with nitrous....
Old Aug 19, 2006 | 02:10 PM
Audible Mayhem
My350z
let me know, i am looking for a building as we speak, i will hook it all up for ya!!
Old Aug 19, 2006 | 02:41 PM
woodstock300s
thanks for the info ..ur absolutely right..i want it done the safest way..so im just gonna save up for a utec then..thanks again
Old Aug 19, 2006 | 02:54 PM
ericinmia's Avatar
ericinmia
Look at the window switch/fuel switch/af switch from DynotuneNitrous
you can have a really "SAFE" setup without the extreme expense of the Utec. People on here have been running nitrous for YEARS without the Utec. Especially a small 75 shot would be no problem. I know personally many vq35's that have run 125 shots stock block for over a year with no problems.
-Eric
Old Aug 19, 2006 | 04:00 PM
Audible Mayhem
My350z
i ran 100-150 shot for two years on two different vqs without a utec. it is much easier to run a utec and have the safety of a knock sensitive timing retard function.
just throwing out options, hell i had mine with just a button with no switches for a while...
Old Aug 19, 2006 | 05:06 PM
ericinmia's Avatar
ericinmia
Whats the price on the Utec now? I remember it being around 1k before i think.
How complicated is the install for the utec? Does it come with the software so that you can program it from your laptop? Thanks.
I'm at the stage where i'm going to buy a nice Titan truck, but keep the g35. So i'm going to run nitrous again, and if it blows up. I'll get my truck and then start working on the g35 again.
Old Aug 19, 2006 | 05:07 PM
woodstock300s
1049$
Old Aug 20, 2006 | 05:36 AM
Miraclekidjr
http://www.radtoyscentral.com/store/...oductid=117365
$849
Old Aug 20, 2006 | 04:16 PM
Audible Mayhem
My350z
i have utecs in stock and will be able to walk you through the install and hooking up the nitrous if interested. i have had it on two personal cars hooked up that way and know all the ins and outs. please pm me if you would like a price on utec or nitrous. prices are fair but the knowledge and customer support you will get is priceless... thanks
Old Aug 20, 2006 | 08:00 PM
ericinmia's Avatar
ericinmia
I ran a straight NX kit for a while... then none... then a maximizer, with ALL the little extras.. then and now.. none again.
Not sure if/when i'm going back to nitrous, or if i should do something else.
I want to be in the 400rwhp range. But i dunno.
Old Aug 21, 2006 | 09:39 PM
woodstock300s
is there really no need to do an ecu reflash with a 75 shot of nitrous?...i just want to make sure its ok to run a 75 shot on the stock computer without changing anything
Old Aug 22, 2006 | 09:04 PM
first350's Avatar
first350
I'm running a 75 shot and just got my dyno done...AF's in high 11's, 1 step colder plugs - no reason to pay for a tune besides getting a few more HP out of the set.
Old Aug 25, 2006 | 07:57 PM
woodstock300s
how/where is the window switch/wot switch wired into the car?
Old Aug 26, 2006 | 07:26 AM
first350's Avatar
first350
I'm using the dynotune window/tps switch...it's a small 3"X2"X1" module that can be placed just about anywhere within the car. (I have it in my ash tray). The wires are:
-TPS signal
-Window signal
-Power (12 Vdc)
-ground
-Ch1
-Ch2
...I think that's it. The unit allows you to program different setting for Ch1 and Ch2 (this allows you to control 2 stages of nitrous, or differences between 1st gear launches and the remaining gears). Ch1 and Ch2 are connected to the relay which will supply power to the solenoids.
hope that helps.
Old Aug 26, 2006 | 10:18 AM
Wholey Smokes's Avatar
Wholey Smokes
thanks
jeremy
I've already got a UTEC. What else do I need in order to make it functions as a tps/window switch? Does Turboxs make a special nitrous solenoid for the UTEC or can I just wire in any generic (NX, etc.) solenoid? I'm not sure when (today, next week, next month) but I will be running nitrous by the end of this year and I want to have a high-end set-up for a 125-150 shot that is as safe as possible (idiot proof).
Other than the items mentioned, what should I be looking for? Bottle heater, remote opener, blow down tube, nitrous pressure gauge? Most people on this board seem to agree that NX is the best brand so I'll most likely go with their product. I've been reading a lot of threads on nitrous but with work full time, school full time, and now SCUBA training I tend to forget what I read.
I'm hoping that I can just open the bottle, set the UTEC to my nitrous map via the remote switch, and let the UTEC (and other equipment) do everything else.
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
