Nitrous Oxide Too soon, jr.
Need help with utec / zex
Old Aug 28, 2006 | 05:56 AM
vze4fhpv's Avatar
vze4fhpv
Default Need help with utec / zex
I wish to sue my utec as a window switch. Does anyone run this setup, if so can you please pm with instructions for doing so.
I am aware of people using other systems, but the zex kit's selnoids are sealed in a box and works off wide open throttle only....
Old Aug 28, 2006 | 07:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
ive heard the utec can be used as a window switch and a throttle position switch.
audiblemayhem may be able to shed some light...
but, while im here, did you install the zex kit yourself? I cant get the led on my zex to light up, i know it has power/ground but what im wondering is if it needs the tps signal too (its hooked up, just havent double checked to make sure the t-tap did the trick).
Old Aug 28, 2006 | 11:06 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
pmed, hope i helped out. its pretty easy to do... just remember the utec is a switch that switches the GROUND, i hook this to the relays that controls the solenoids on the ground side of the relay...
Old Sep 23, 2006 | 03:57 AM
vze4fhpv's Avatar
vze4fhpv
Still having no luck with this.. my shop can't figure it out. Trying but no luck so far. I'm actually thinking about removing the utec all togeather... my car drives so much smoother without it on. Plus with my 100hp shot i think I'm ok on stock ecu.... not as fancy but sometimes simple is better.
Old Sep 24, 2006 | 07:50 PM
XBS's Avatar
XBS
Veteran
if your car drove better before, that means you need a new tuner
Old Sep 26, 2006 | 03:56 PM
Audible Mayhem
My350z
ok, make sure the shop knows this...
Most switches in cars actually switch the power side of something.
the utec switches the GROUND side of it, it needs to still have power fed to the relay like normal but instead of grounding the relay normally, you run the ground to the wires off the utec, the little black wire needs to be grounded to the car and the red wire is the switchleg.
call them and tell them what i just typed and hopefully they can figure it out. the utec doesnt supply power to anything...
Old Oct 22, 2006 | 11:02 AM
roro's Avatar
roro
i'm also looking at a zex/utec setup and if i could use the utec as a window switch, it would save me another $150. can you PM me the info on how to get this working audible?
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Slidewayz350Z
Nitrous Oxide
May 9, 2004 05:45 PM
fluidz
Nitrous Oxide
Apr 11, 2004 09:56 AM
