Nitrous Oxide Too soon, jr.
Show your jets!
Old Jan 16, 2010 | 08:48 PM
  #41
Hostetler's Avatar
Hostetler
here are some pics
Old Jan 16, 2010 | 08:50 PM
  #42
Hostetler's Avatar
Hostetler
Originally Posted by tollboothwilley
What is the scare with having your window switch set lower than 3000 rpms?
to much torque for the stock rods to handle..bent and/or broken rods
Old Feb 15, 2011 | 09:19 AM
  #43
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Bump for the new guys.
Old Feb 18, 2011 | 10:39 AM
  #44
Italianjoe1's Avatar
Italianjoe1
lol, thats a serious bump.
Jetting is dual 37/22 for now, af is holding steady around 11.2 on bottle. No dyno or track times as yet.
Old Jun 2, 2011 | 10:21 AM
  #45
Italianjoe1
Ran a 13.1 at 111.9
Old Jun 2, 2011 | 10:39 AM
  #46
3hree5ive0ero
Retired Admin
^ Time slips? With that trap, you should be at least mid 12s on street tires.
Old Jun 4, 2011 | 09:46 AM
  #47
Italianjoe1
They are at home, i'll try to post them later on.
60' that run was a 2.15 or so, I got down to a 2.05 later on but I was not spraying anymore, I ran the car 11 times that night, and the spray runs didn't feel like they had the power they should so i stopped spraying. Went a best of 13.56 on motor with the 2.0 60', at just under 104mph.
Old Jun 4, 2011 | 11:03 AM
  #48
3hree5ive0ero
Retired Admin
8mph pick up isn't bad, especially considering the hot weather you're probably in. I trap around there, too, in TX. We can't expect to see similar times as the northern drag racers. Another thing you might want to take a look at is your fogger position. Either way, you're running 13s with a 112 trap, which means you need more practice.
Old Jun 4, 2011 | 11:24 AM
  #49
Italianjoe1
Yeah, it was in the 80's at night lol. I don't even try to spray the car until im firmly into second gear, I got my lauches quicker at the end of the night, if I felt like spraying again the car had a 12 sec pass in it, i dropped a full tenth off my 60' which is usually good for .2 in the 1/4. Another time, no rush. Preferrably with HFC's or something, stock cats are killing the power.
Old Dec 13, 2011 | 03:33 PM
  #50
denchan350gt's Avatar
denchan350gt
Zex nitrous kit using a NX nozzle
Nitrous - Fuel / Gas Octane / Timing / Power / A-F / E.T./ bottle pressure
57 - 35 / 93 / uprev n20 tune / 384hp - 380trq. / 11.5 / 12.3@114/1025
http://youtu.be/b4eJALpBs84
Old Dec 13, 2011 | 08:15 PM
  #51
3hree5ive0ero
Retired Admin
Nice. I wish I can rev out to 7.5K rpm. What exactly is cut off (fuel, ignition, etc) when you hit the rev limiter? I'm afraid of hitting the rev limiter on spray since I don't exactly know what is being cut off.
Old Dec 14, 2011 | 01:35 AM
  #52
denchan350gt
Fuel is being cut my window switch is from 3500-6800. I'm a DE with cams my rev limit is set to 7200 the tach reads 200-300rpm higher on DEs.
I don't spray through the shift 3rd gear in my tranny doesn't like it.
Old Dec 14, 2011 | 06:09 AM
  #53
Italianjoe1
Factory limiter cuts fuel if you exceed the throttle plate closing limiter. If it's been adjusted, you can choose what you want. I know with the COBB you can set a throttle rev-limit, a fuel limit and a spark limit. From the factory they are staggered in that order.
BTW, the car on the spark limiter sounds nasty with a loud exhaust. It's a very rapid limiter, sounds like a machine gun. Quite sexy
Old Dec 14, 2011 | 12:52 PM
  #54
3hree5ive0ero
Retired Admin
If only the fuel is being cut off then, I guess it's good I never hit the rev limiter. After all, you're spraying a wet shot, which has fuel in it. So, a spark will lead to combustion of the nitrous/fuel mixture + air from intake but without the proper fuel added by the injectors, leading to a lean condition.
Old Oct 10, 2012 | 03:48 PM
  #55
Taz394's Avatar
Taz394
Good thread ... Bump for good info
46N 26F / 93 / 0º / No dyno / 12.1 / 12.9 @ 107mph
57N 35F / 93 / 0º / No dyno / 12.8 / 12.9 @ 113mph (spin fest LOL fml)
this was a stock motor
i have a built motor now on direct port and Q16 sitting on 28" slicks so it should be interesting
2004 Maxima VQ35x
Old Oct 10, 2012 | 06:43 PM
  #56
Italianjoe1
2004 Maxima VQ35x
Nasty trap speed for sure, car must be strong on the highway.
I am going to the track next week wendesday, i'll post up times on my current setup.
Old Oct 13, 2012 | 04:28 PM
  #57
Old Rice's Avatar
Old Rice
2006 350ZR 5AT (+shift kit, 3.5FD swap)
Nitrous Outlet Wet + 4500 NANO
@ 950psi
52N 30F | 100oct | -4d | 317whp 355wtq | 10.8-11.2 AFR |ET TBD
Results are Dyno Dynamics 4th gear pulls, 216whp NA baseline, 101whp net gain
Justin100
Nov 25, 2021 06:26 AM
May 30, 2017 03:28 PM
Tochigi_236
Sep 27, 2015 03:40 PM
