Nitrous Oxide Too soon, jr.
Nitrous wet kit or Water injection?
Old Mar 30, 2007 | 05:35 PM
priscilla ls1's Avatar
priscilla ls1
Default Nitrous wet kit or Water injection?
Ok I was wondering what kit would be more beneficial to me. A Nitrous wet system (100-150shot) or a coolingmist/sparco universal water/meth injection kit. I need to pick one or thee other and if you had the mods I do and do more drag racing what would you go with? And why?
Old Mar 31, 2007 | 10:03 AM
bldrz's Avatar
bldrz
If I were you I would continue to increase the boost. Run a high boost map for the dragstrip and a low boost map for the street. The water injection is typically used as a safeguard against detonation rather than a power adder. Some people may run slightly more timing with "water injection" to gain a little more power. But I personally don't think it is worth the risk for the power gained. If for some reason you don't want to increase the boost than nitrous is a better way to go if your primary goal is dragstrip performance. Jason
Old Mar 31, 2007 | 09:19 PM
priscilla ls1
Thanks Jason, I was thinking maybe a 75 shot just to get me out of the hole and nothing more, I think I'll be safe with it.
Old Apr 1, 2007 | 07:14 AM
bldrz's Avatar
bldrz
No problem. Post up some pics of your set-up when you get the nitrous installed if you don't mind. A 75 shot should really "wake up" your turbos. Jason
Old Apr 1, 2007 | 07:17 AM
bldrz's Avatar
bldrz
priscilla ls1, just read your pm. I will have Eric send you a pm tommorow with info. Thanks, Jason
Old Apr 1, 2007 | 11:07 AM
priscilla ls1
Thanks again Jason.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
