Nitrous Oxide Too soon, jr.
Dry Nos at WOT?
Old Apr 16, 2003 | 11:44 PM
Toronto350Z's Avatar
Toronto350Z
Default Dry Nos at WOT?
I have one question about dry nitrous setup.
When a car is in W.O.T. with injecting dry nitrous, the ECU does not have time to get feedback(instant amount of oxygen entered via intake)from the oxygen sensor and follow usual fuel-air mapping. Am I correct? Doesn't this cause knocking and damage the engine?
Please, I need input!!
Old Apr 17, 2003 | 08:32 AM
D_Nyholm's Avatar
D_Nyholm
AFAIK, the nitrous goes across the MAF and cools it thus forcing the computer to add more fuel. There is a maximum that the computer can adjust to and that will be the max you can shoot into the motor. It is a good safety feature to get an A/F gauge to see if you run lean at any point and that is basically the max you can shoot into the motor without going to a wet kit. I hope that huge run-on sentence helps you out a bit.
Old Apr 18, 2003 | 12:16 PM
SR20DEN's Avatar
SR20DEN
Any Zex or NOS dry system boosts the fuel pressure to meet it's fuel requirements. You aren't supposed to spray nitrous though the MAF. And if the Z fuel system is anything like the 'returnless' one in the Maxima you can't just install the kit and go. You will need an external booster pump and external regulator since the stock fuel regulator is in the fuel take. Also, it supplies 3.5 bar or about 52psi of fuel pressure instead of the traditional 3.0 bar or 43psi.
Old Apr 18, 2003 | 07:40 PM
12SecZ's Avatar
12SecZ
ZEX Tech discouraged me from the booster pump, said it wasn't needed in our cars. The bottle and module control the amount of fuel (for wet)
FWIW.
I agree about the AF thing and am purchsing one (Apexi)
Old Apr 18, 2003 | 07:51 PM
SR20DEN's Avatar
SR20DEN
FWIW.
Thats because they sold you a wet kit. You don't boost the fuel pressure with the wet system. What # fuel jet are you using? NOS can't get it through their skulls that the Maxima isn't running at 43 psi. I wonder if Zex knows that about the Z.
etkms
Jun 19, 2022 06:30 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Bigsyke
Sep 11, 2015 06:19 PM
