Nitrous Oxide Too soon, jr.
what compression would you run???
Old Oct 3, 2007 | 01:55 PM
ronie's Avatar
ronie
Default what compression would you run???
aite, im looking and planning for mods on my 07hr base model, would like to build and shoot bout 200-300 shot of juice what compression would you guys recommend, also does anyone know of ecu upgrades yet? what lsd should i use(a mix between street and drag) or should i leave mine...any cams?
Old Oct 3, 2007 | 03:25 PM
eltness350's Avatar
eltness350
The Untouchable
10:5:1 ...and make sure u get piston/rods that r made for big nitrous shots like that....gl
Old Oct 3, 2007 | 04:13 PM
coachk's Avatar
coachk
You might want to consult with a guy named JT up in Orlando...just a suggestion. Performance Factory knows nitrous and FI. I wouldn't attempt this yourself
Old Oct 3, 2007 | 04:25 PM
HondaKiller's Avatar
HondaKiller
that is a huge shot. plan a total rebuild of that brand new engine. Roll with a 125 shot and you'll chop your cost severly.
Old Oct 3, 2007 | 06:59 PM
ronie's Avatar
ronie
i do plan to build the motor, but i plan to start with the basics 100 shot until an engine management is available for the hr then build the block, port the heads, cams, and valves...i basically plan to build it for 1/4 mile but some street action as well, by the way its going to be a direct port if i decide on a big shot like a 300....lets just wait and see
Old Oct 3, 2007 | 08:12 PM
go-fast's Avatar
go-fast
built motor,pump gas,10.25 to 1,it'll be nasty on and off the bottle.
Old Oct 4, 2007 | 05:24 AM
Old School's Avatar
Old School
Shift_Boost
Originally Posted by eltness350
8:5:1 ...and make sure u get piston/rods that r made for big nitrous shots like that....gl
nitrous is not boost....you don't run low compression on nitrous..
Get a good tune and build the motor just like you are for "all-motor"....say 11.0:1 or 11.5:1....if you have a good tuner, a big shot and high compression are excellent for nitrous. I would recommend a two stage system or a nitrous controller like the maxmizer so you can bring on the nitrous slow.
If you go 150 on stage 1 and 150 on stage two...that is definitely do-able. The maximizer would be your best bet as you can control the percentage of nitrous without having to use a two stage setup....start with 35-50% on your direct port 300 shot and ramp it up as the RPMs go up. I can only imagine what kind of torque you'd be putting down. I was going to go this route, but have ultimately decided on twins and nitrous which will all be done next week! woo hoo. Good luck with the build. Nitrous is alot of fun.
Old Oct 4, 2007 | 05:28 AM
myladyz33's Avatar
myladyz33
lol i was gonna say the same u dont lower comp for n/a or spray but yea pm audiblemayhem (jeremy tibbs) he will get u where u need 2 be
Old Oct 4, 2007 | 07:42 AM
ronie's Avatar
ronie
thanks guys, ive heard both sides of the the story some people say you need to run low compression as if you were boosting the car, but then i see all the muscle cars and drag cars out there running super high compression and a big shot...so was really confused on that, and also if i run a 8.5:1 wont my motor suck without the juice, remember i plan on street use for the car...
Old Oct 4, 2007 | 07:45 AM
go-fast's Avatar
go-fast
11 to 1 seems a little steep for pump gas
Old Oct 4, 2007 | 10:08 AM
Old School's Avatar
Old School
Shift_Boost
my bike is 12.5:1 STOCK....and it runs on pump gas.
RSX Type S is 11.0:1 STOCK....
the list goes on.
I have been running nitrous on all my cars for the better part of 12 years....I do know a thing or two about spray. =P
Old Oct 4, 2007 | 10:16 AM
go-fast's Avatar
go-fast
the list goes on.
i have a little experience as well,and was considering the negative effects of the timing that would have to be pulled on the vq to run that high of a compression ratio.
Old Oct 4, 2007 | 10:21 AM
garym's Avatar
garym
My '68 Chevelle SS396 is 14:1 at almost 700HP.
I ran a 200HP nitrous shot on it ONCE and scared the $h^! out of myself.
I didn't think the front end was ever going to come down.
I had the choice of wheelie bars or NO nitrous.
I went with NO nitrous because running a 10.7 is fast enough for me.
No need to jump into the 9's on a street driven car.
You need to consider now what you may want to do in the future.
If you go high compression now for nitrous, and decide later to go FI, then you'll be building again.
Decisions, decisions, decisions
Old Oct 4, 2007 | 10:28 AM
Old School's Avatar
Old School
Shift_Boost
stock compression is 10.3:1 on the Z....11.0:1 is not that big of a jump. You can only go so far with pulling out timing before you toast the exhaust valves. I ran 150 shot on stock compression just fine. I seriously doubt he'll have a problem running more nitrous in the higher rpms with a similar setup. Especially running forged internals. I'd say take out 4-6 degrees of timing on 11.0:1 or 11.5:1 compression and work on the fuel. 150 shot @ 3500rpms....and another 150 shot at 5k rpms. You can ramp this up with the maximizer....
Jeremy is running an insane amount of compression on a nitrous motor for the Z. 15.0:1 I believe.
Old Oct 4, 2007 | 10:29 AM
Old School's Avatar
Old School
Shift_Boost
+1....one reason I went the route I did....8.5:1 big bore, twins and nitrous....yummmmy. lol.
Old Oct 4, 2007 | 10:35 AM
iStan's Avatar
iStan
ZR
Dude, 12 years, time to grow up and get off the bottle. I keed I keed!
Old Oct 4, 2007 | 10:46 AM
go-fast's Avatar
go-fast
yeah high compression is totaly the way to go,i just thought he was looking for mild street manners,personally i build on the excessive side but my advice is always cautious.by the time you take 6 degrees out the .7 cr ratio has little if any effect and leaves you worrying about gas quality.
Old Oct 4, 2007 | 11:50 AM
Old School's Avatar
Old School
Shift_Boost
my cousin use to say the same thing..lol. "you're bottle fed...hahaha". Now he just says, "jeeeeeeeeeeeeeezus, you make too much money. Wish I had twin turbos" lol. I always find it funny how he forget to mention the nitrous. lol.
Old Oct 4, 2007 | 03:48 PM
coachk's Avatar
coachk
Nitrous loves high compression motors..the only way to go.
Old School your right about Jeremy..he was doing a 15:1 with N20
Old Oct 4, 2007 | 04:08 PM
NA&CH's Avatar
NA&CH
Did JT ever have N20 on it?
Chris
