Nitrous install
Any good write-ups on here for a nitrous install. All I want to do is mount the bottle, and run some hoses. Going to let the install shop do the rest. Any help is mucho appreciated.--drew
It's not that bad to do yourself. The hardest thing was running the wires/line through the car. If you have some understanding on how an electric circuit works you're almost there. Save some cash and do it yourself. Dynotune buyer know what I'm talking about.
thxs for all the help...but could use a write-up....anyone know where to get one? Should be good with the guages...best bud is an electrical engineer..Just need to run all this stuff to the engine bay
Check out this install video on You Tube. A simple Nitrous set-up is wired the same way. Only difference is if you want a direct injection port in your intake.
Otherwise, the tank install is the same, and the routing of lines is generally the same.
http://www.youtube.com/watch?v=INCIGC9jdV4
Check it out. At least this will give you an idea of what is involved. It is not as hard as a lot of folks think.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
