Nitrous Oxide Too soon, jr.
Is a 75 shot safe?
Old Nov 6, 2007 | 01:45 PM
frankie945's Avatar
frankie945
Default Is a 75 shot safe?
I have a zex kit. Is it safe to run a 75 shot on a stock Z just have a k&n typhoon cold air intake and 5/16 plenum. I have heard you have to adjust timing. New to Nitrous
Old Nov 6, 2007 | 01:51 PM
SuperBlack350z's Avatar
SuperBlack350z
for a 75 ZEX, it's safe.
zstreet86's Avatar
zstreet86
im no expert but it certainly wont help the life of your engine
Old Nov 6, 2007 | 01:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
since you know youre new to nitrous, why not read the sticky? its not hard and would have answered your question and youd learn a lot more as wel.
please read this : https://my350z.com/forum/nitrous-oxide/218158-nitrous-basics-thread-read-here-if-you-want-nitrous-for-the-first-time.html
Old Nov 6, 2007 | 02:55 PM
RebelinRI's Avatar
RebelinRI
Don't tell me this is going to start in this section too!
Old Nov 6, 2007 | 03:32 PM
GolfinZ's Avatar
GolfinZ
A Zex 75 shot on a Z is very safe since the shot is rated at the crank, not the wheels. As with every form of FI, you cant use it ALL the time or things will come apart.
Old Nov 14, 2007 | 09:53 AM
Manchester's Avatar
Manchester
75 shot is fine its not 150. These turbos and superchargers getting 8 plus lbs and they are not blowing up well most of them but anyways 75 is not a whole lot just do right the first time and even with a 75 shot I would still probably put a 1 heat range colder spark plug and make it cooper that doesnt hurt.
Old Nov 15, 2007 | 09:03 AM
tenpenniesz's Avatar
tenpenniesz
please read this : https://my350z.com/forum/showthread.php?t=218158
I've being running 75shot for the past two years. Not issues. As with anything be safe and take the necessary precautions.
P.S When I got my nitrous kit I spent a lot of time reading the sticky and searching the forum like CUxtopher mentioned. A lot of good info out there. If you're thinking it chances are someone has already written about it.
Old Nov 19, 2007 | 04:38 AM
Manchester's Avatar
Manchester
I agree- their are to many people blowing up their engine these days!! Read lots of material and play it safe at first until you get used to the performance increase. Force induction is bad-*** until it turns catastrophic.
Old Nov 28, 2007 | 11:09 AM
xplatboarder669's Avatar
xplatboarder669
zex is a very week shot, zex measures there gains at the crank and not the wheels......so yes, a 75 shot would be perfectly fine. i dont even see a need for tuning nor retarding your timing. just grab one step colder plugs and call it a day
Old Dec 15, 2007 | 08:39 AM
Q45tech's Avatar
Q45tech
Study the mathematics concerning how imaginary HP was created, an adaptation of torque vs rpm and you will better understand limits.
Since the volume from the jet is constant, all that varies is the rpm or NOX quantity PER GULP [each cylinder filling].
A 75 HP jet might create 65 lb/ft at 6,000 rpm and 130 lb/ft at 3,000 rpm and 260 lb/ft at 1500 rpm.
Engaging NOX at too low an rpm is the STRESSOR.
Why multivibrator type pulsed solenoids are used as flow valves to control NOX vs rpm to lessen low rpm stress and not smoke the rear tires on launch wasting time.
Old Dec 15, 2007 | 04:25 PM
CRAYY Z's Avatar
CRAYY Z
looks like I need to do a lot of studying...
Old Dec 15, 2007 | 04:39 PM
RebelinRI's Avatar
RebelinRI
Q is the Numbers man around here. He likes throwing stuff like that up. Hey Q, no formula to figure this out? J/K buddy
Old Dec 15, 2007 | 07:34 PM
BootieMAN's Avatar
BootieMAN
Ran a 75 shot for over 3 years and no problems. As with any power adder, doing your homework is very important. Search the nitrous threads and do it right the first time. Good luck.
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
FromGtoZ
Sep 20, 2015 03:41 PM
