Nitrous Oxide Too soon, jr.
A quick warning........
Old Mar 12, 2008 | 03:38 AM
MikeEwithTheZ's Avatar
MikeEwithTheZ
Originally Posted by jksstar
you can use the bottle in 5th gear.
+ 1 i have used several times in 5th on a 125 shot
Old Mar 12, 2008 | 09:18 AM
KRRZ350's Avatar
KRRZ350
Originally Posted by DRELOC
So basically highway runs is a no no for N2O??? I usually let off after 4th gear anyways when i raced....is that good if you're bottlefed??
Basically the engine needs to be in a condition where once the spray hits it can rev out. That's why:
1. Lower gears are safer
2: it can't happen at to low of a rev, or while you bang the limiter.
3: It must be at WOT
The ability to rev out, this is also the reason why, let's say in 1st gear you can spray @ 2500rpms, but spraying @ 2500 in 5th wouldn't be so smart. This is why, with a manual you would want to set the lower threshold on your window switch @ oh lets say 4k rpm's while you are a beginner, but once you get used to spraying you can lower it down to 3k or 2,500 but not hit the button until 4k in a higher gear. This is one reason why it's good to have a pushbutton switch wired in conjunction with your wot & rpm switches, it gives you final control.
Old Mar 12, 2008 | 10:49 AM
ct350z's Avatar
ct350z
Originally Posted by Blu_Blur
my mom= Fail
well she did have you!!!
Old Mar 13, 2008 | 01:06 AM
DRELOC's Avatar
DRELOC
Hey Mike u still on the juice or going boost now?? I've watched all your runs on youtube.....crazzyyy!!!
Old Mar 13, 2008 | 01:08 AM
DRELOC's Avatar
DRELOC
Thanks for the knowledge bro...it all makes sense now
Old Mar 13, 2008 | 08:23 AM
MikeEwithTheZ
No i sold it...going turbo
Old Mar 16, 2008 | 05:48 PM
nareg's Avatar
nareg
ive done 5th once but never again, i felt bad for the car after that...
Old Mar 25, 2008 | 07:10 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
way too lean, should have had it tuned. you can tell by the heads. wrong fuel jet used...
sorry about your luck!!
If you hold the button for "I'm not really sure, probably between 15-20 seconds in 5th on the highway"
You will end up with this, as well as other minor things like a blown HG and a partailly messed up cylinder wall.
Every other precaution was taken, running a 100shot w/window switch, wot switch, and even a fuel pressure cut-off (not that that will always prevent anything, but it is slightly good measure)
Old Mar 25, 2008 | 10:24 AM
drap660's Avatar
drap660
I have sprayed my car from 2nd all the way to six on a good 30 highway pulls with no problems. jeremy was right, that tune looks way to lean. With a proper tune you have no problem spraying any gear
Old Mar 26, 2008 | 01:30 PM
Mikelous's Avatar
Mikelous
damn.
Old Mar 26, 2008 | 01:43 PM
06MagneticZ's Avatar
06MagneticZ
Where are those videos someone mentioned on nitrous?
Old Mar 26, 2008 | 02:01 PM
MikeEwithTheZ
well you can search my name on youtube i have uploaded several
Old Mar 26, 2008 | 02:20 PM
06dieselZ's Avatar
06dieselZ
were you on the bottle in every vid??
Old Mar 26, 2008 | 02:22 PM
MikeEwithTheZ
not in the rsx-s vid, or the Porsche 911 vid...i think so on all the others
Old Mar 26, 2008 | 02:27 PM
06dieselZ's Avatar
06dieselZ
damn what year was the 911?
Old Mar 26, 2008 | 02:33 PM
MikeEwithTheZ
im not sure its not a turbo just a cabriolet
Old Mar 26, 2008 | 02:50 PM
Blu_Blur's Avatar
Blu_Blur
Now that's the way to go!
Turbo'ing > Nos
Old Mar 26, 2008 | 04:07 PM
  #38
MikeEwithTheZ
Turbo'ing > Nos
if i wasnt planning on tracking the car i would have just done a mild bottom end build and direct port...would have been cheaper and a ton of fun on the street
Old Mar 28, 2008 | 03:52 PM
  #39
Fishey's Avatar
Fishey
So to sum up this thread we learn the person who made the topic is very close if not MRDD about cars. Anyone who claims using nitrous above a certain gear causes damage is also MRDD. So its my conclusion that alot of people on here should be looking for a new hobby maybe playing with Lincoln Logs would be a good switch.
Old Apr 4, 2008 | 04:15 PM
  #40
michael22force's Avatar
michael22force
Default huh
Mrdd?
