VQ35HR specific Zex Nitrous kit just arrived
on
Originally Posted by powermark
11s might be tough, im going for low 12s myself. you can run an EMS or an F Con pro, etc.
i plan to install my kit in about 2-3 weeks.
do you know any DRs that are in the 245-255 range for the 18s? nitto doesnt make a 555r
BFGoodrich makes a 275/35/18 drag radial. I had the 295/35/18 BFG drag radials and I liked them alot. I had many low 12 second runs on them
_______________
Originally Posted by sekret
i will be ordering this zex kit and drag radials within the next month, hopefully i can be one of the first HRs that touches 11s! anyone know of a good standalone i could run for a track nitrous / street car? would aem ems work on the hr?
on
275 35 on the oem 18s?
Originally Posted by gsingh350Z
I don't mean to rain on your parade, but 11s? If you can get 11s then more power to you, but I don't know.
Originally Posted by coachk
I don't think so....what size are the oem 18's that you have? I have used the 275 on a 15x8 Weld wheel. IMO it would be well worth it to invest in a set of 15x8 Weld Pro Stars if you plan to take it to the track alot. They are considerably lighter than the oem 18's. If you're really shooting for low 12's or even high 11's then don't skimp on the rear wheel set up
Originally Posted by infinite
That's cool... I didn't know there was HR specific kits out
http://www.dynotunenitrous.com/store...?idproduct=260
Another hr specific kit. A well modified hr with nitrous
#39
what wire did you splice into? there is two output wires that come from the tps one blue with yellow and another wire..
how did you set the smart box ?
by manually opening the butterfly or by depressing the gas pedal method...
LMK!
Travis
#40
on
Then after it reads the voltage, to test it and make sure it works. Open the throttle blade again wide open again and listen for the clicks of the solenoids opening in the zex brain.
