Nitrous Oxide Too soon, jr.
spark plugs?
Old Jun 27, 2008 | 10:53 AM
2boosted4u's Avatar
2boosted4u
Default spark plugs?
i was lookn at the newbie section for the spark plugs recomanded and i didnt see any specific plugs?? i was lookn for part numbers of any ngk or plugs you guys run.. im goin to be runing prob 100 shot not sure yet but either 75/100 around there. thanks in advanced!
Old Jun 27, 2008 | 11:15 AM
eltness350's Avatar
eltness350
The Untouchable
NGK LFR6AIX-11
those are iridium one step colder then stock...should be great for your setup...
Old Jun 27, 2008 | 12:08 PM
2boosted4u's Avatar
2boosted4u
right on bro!
Old Jun 30, 2008 | 09:19 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would do NGK 3672 LFR 6A-11 they are one step colder and copper. they will work better with nitrous...
Old Jun 30, 2008 | 10:34 AM
j.arnaldo's Avatar
j.arnaldo
Owner's Manual provides 3 alternatives.
Old Jun 30, 2008 | 12:23 PM
eltness350's Avatar
eltness350
The Untouchable
if jeremy says go copper....u should
Old Jun 30, 2008 | 02:16 PM
garym's Avatar
garym
+1 on the copper.
Copper is more resistant then Iridium to chemicals such as the sulfur that is added to non-medical grade nitrous (to prevent huffing).
Old Jul 1, 2008 | 04:08 PM
BakaN20's Avatar
BakaN20
I was wondering what gap. I have seen gaps recommended from .036 to .042. What is the consensus here. And how do you make the gap smaller. I know you use the gapping tool to make the gap wider but how do you make it smaller.
Old Jul 2, 2008 | 07:03 AM
garym's Avatar
garym
I run .036
And I believe it was Audible Mayhem that recommended that gap in another forum a while back.
But If Audible Mayhem chimes in on a gap, I'd run what ever he suggests.
He knows more about nitrous then anyone else on this site.
Old Jul 2, 2008 | 09:53 AM
coachk's Avatar
coachk
If you're using the Iridium or Copper the gap out of the box is .044. Try them at that gap and if you decide to make the gap on the Iridiums smaller, be careful because those tips are fragile. IIRC making the gap smaller richens up your A/F which makes it a little safer.Usually if your running big boost you would make the gap smaller in order to prevent blow out or misfires. Bigger gap (.044) equals better performance. I have never changed the gap(.044) on my plugs and I run TT & N20
Old Jul 3, 2008 | 03:10 PM
GrayG35's Avatar
GrayG35
so for an NA vq on a 75 or 100 shot, 1 step colder copper ngk plugs should be fine at .44 gap correct?
Old Jul 3, 2008 | 04:14 PM
coachk's Avatar
coachk
Yes
Old Jul 3, 2008 | 05:29 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Jksstar, in the stickied thread in this subforum, stated his is gapped at 35, so a lot of people were going by that also.
You also have to remember that you're tuned and many aren't. Running safe is and should be your #1 priority.
Old Jul 10, 2008 | 11:57 AM
2boosted4u's Avatar
2boosted4u
o fer sher good lookn out bro i just ordered em
Old Jul 31, 2008 | 05:13 PM
Ruthless18x's Avatar
Ruthless18x
Does anybody know a good place to get the copper ones? I called 4 shops today and no one had them.
Old Jul 31, 2008 | 06:14 PM
3hree5ive0ero
Retired Admin
You can get them online or your local automotive stores (NAPA, AutoZone, O'Reily's, etc). From my experience, NAPA had them for the lowest price.
Old Aug 3, 2008 | 01:16 AM
KAZ350Z's Avatar
KAZ350Z
I went to NAPA to get a new battery for another car in tampa so I figured I'd ask to see if they had them just to check (I'm usually in colorado), and they did but it didn't say they were copper or anything, it had the right numbers but looked like a regular silver looking NGK plug in the original NGK box??? Are those the right ones??? thanks in advance
Old Aug 3, 2008 | 05:11 AM
coachk's Avatar
coachk
My photo skills suck: the one on the left is the copper and the one on the right is an Iridium(both NGK) Coppers are LFR6A 11 Iridiums are LFR 6AIX-11
If you look real close at the tips on the bottom of each, the Iridium is much smaller than the copper so be careful if you gap the Iridiums
Old Aug 3, 2008 | 01:31 PM
3hree5ive0ero
Retired Admin
As long as you get the NGK LFR6A-11, you should be fine.
Old Sep 3, 2008 | 06:49 PM
KAZ350Z's Avatar
KAZ350Z
It's been a while since i asked, but I just wanted to say thanks, looks like I'll finally put them in in the next week or two
