Nitrous Oxide Too soon, jr.
Cars Shuts off
Old Feb 19, 2009 | 03:01 PM
carlos305's Avatar
carlos305
Default Cars Shuts off
i am having a problem with my nitrous set-up i am running a 75 shot with colder plugs, rpm window switch ,warmer ,etc and my problem is when i spray my car and i left off after fourth the engine shuts off any reason for this? i have never sprayed 1st 5th or 6th....
Old Feb 19, 2009 | 07:47 PM
genegoesfast's Avatar
genegoesfast
are you putting the car in neutral after 4th? If so, its the popcharger. The MAF doesn't no what to do with the airflow.
Old Feb 19, 2009 | 08:48 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Actually, after a bit of driving, the popcharger issue goes away on its own. Or, you manually reset your ECU to get rid of that problem.
As for the OP's question, I haven't the faintest clue without more details. What exactly does the car do? What are you doing when the car shuts off?
Old Feb 20, 2009 | 11:03 AM
JZK's Avatar
JZK
I've experienced the same exact thing, it means your running too rich so your drowning the engine in too much fuel causing the plugs not being able to spark, thus causing the engine to shut off. This usually happens when your bottle pressure is lower then the recommended pressure thus causing an irregular nitrous/fuel mixture making the mixture too rich. For example: If you were to spray all of 2nd, 3rd, and 4th gear, by the end of 4th gear your bottle pressure would be lower then what you started with, thus making too rich of a mixture.
Try spraying at 1100 psi, you should be fine, that's what I spray at and the air fuel is steady at 11's.
Do you have a wideband, and what are your jet sizes
Old Feb 21, 2009 | 08:35 AM
carlos305's Avatar
carlos305
bottle pressure is 1250psi , afr stays in the 11's and jets i don't remember but its a 75 shot on a NOS kit
Old Feb 21, 2009 | 08:36 AM
carlos305's Avatar
carlos305
yes i do put the car into neutral after 4th
Old Feb 21, 2009 | 08:42 AM
3hree5ive0ero
Retired Admin
1250 psi is really high. You want to be between 950-1050, 1100 at max.
Why are you putting it neutral? Why not just shift into 5th or stay in gear then slow down?
Old Feb 21, 2009 | 08:45 AM
carlos305's Avatar
carlos305
now I've got another problem, when i run my car, after a couple runs maybe 5 or 6 2nd to 4th gear 40mph rolls my car makes a noise that sounds like metal pieces loose inside the engine... I've checked oil and i haven't noticed any power loss i actually think its running better but that noise scares me. The noise is completely random so i cant even record it
Old Feb 21, 2009 | 08:52 AM
carlos305's Avatar
carlos305
i'll try too bring down the pressure to 1100 and see if that helps, but now i have a bigger problem
Old Feb 21, 2009 | 10:42 AM
TTwinTTurbo's Avatar
TTwinTTurbo
Default cv
If you have a spacer check to make sure that the strut bar isn't in contact with the plenum. On cold starts it isn't touching but after getting on it and its up to operating temperature I think the metal expands and then it is touching on the left side. Is it vibration? This probably isn't it but nitrous runs seem to increase engine operating temperatures...just a thought
Old Feb 21, 2009 | 11:51 AM
JZK's Avatar
JZK
It makes the noises while wide open throttle?
Old Feb 21, 2009 | 11:56 AM
Spork's Avatar
Spork
Is the metal sound the sound of a piston slapping the cylinder walls?
Old Feb 21, 2009 | 01:18 PM
carlos305's Avatar
carlos305
no it could be at idle or wot its random as hell
Old Feb 21, 2009 | 01:19 PM
carlos305's Avatar
carlos305
if something was blown or broken in the engine wouldn't the noise be constant and notice some power loss?
Old Feb 21, 2009 | 02:19 PM
TTwinTTurbo
it could be a number of things. While it is doing this have you gotten out and checked to make sure there is a clearance between the spacer and plenum? Like stick a business card underneath from the right to the left,
Old Feb 21, 2009 | 05:43 PM
3hree5ive0ero
Retired Admin
Weird. I'm not sure what that could be. I'd have that checked out by a mechanic. In the mean time, I wouldn't drive the car too much, just in case. It doesn't sound too bad, if it's not occurring constantly at all times, but only randomly.
You need to do a lot more reading on nitrous. Nitrous cools the engine when sprayed into it. Go heat up your bottle, open the valve, put your hand AROUND the escaping gas and tell me that's not cold (don't touch, because it can cause frost bite).
Old Feb 21, 2009 | 08:31 PM
TTwinTTurbo
Most things under pressure are cold. I am mentioning this to the OP because I have this problem right now. I'm just havn't had the time to go get spacers to increase the height of the strut bar.
Old Feb 21, 2009 | 11:32 PM
3hree5ive0ero
Retired Admin
You said, "nitrous runs seem to increase engine operating temperatures...just a thought."
I'm telling you that you're wrong. Nitrous oxide will lower the engine temperature.
And no, things under pressure are not cold. I guess you don't know about the ideal gas law (and other gas laws) - PV=nRT. I'm not going to explain this to you, but just know that things under increasing pressure increase in temperature (unless you change volume or the amount). Things under pressure are KEPT/FORCED cool, however, for varying reasons such as reducing reactivity, change in phases, etc.
BTW, I'm almost 100% sure that his metal clanking noise has nothing to do with the plenum hitting the strut bar, so give up on that.
Old Feb 22, 2009 | 09:12 AM
TTwinTTurbo
Good luck OP with trying to get things figured out. Hopefully it isn't anything serious.
Old Feb 25, 2009 | 07:37 AM
JZK's Avatar
JZK
I'm curious to see what the clanking noise is.
