Nitrous Oxide Too soon, jr.
Just sprayed on the dyno. Pig rich as can be.
Old Jul 13, 2010 | 12:13 PM
lee_dfw's Avatar
lee_dfw
Don't use as rich of a fuel pill, and use a cheap time-based progressive controller, and bump it to 125hp =)
Set it to 50% at 0 sec, 100% at 1 sec. One, it won't go 'as' lean at that spike, and two, when it does spike, it will be spraying only half the amount of n2o/fuel, making it less likely to do any damage over the long term.
Also, pulsing your solenoids for 1 second at a time isn't going to hurt them at all. It's the guys that use the RPM based controllers and pulse them nearly the entire time that they are spraying that wear em out quick.
Old Jul 13, 2010 | 12:56 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by izit26
I just want one 11.9 pass on an open diff with no tune other than reading plugs and the occasional dyno.
Me, too, and I'm so close. I haven't been back out with my current clutch, but I know it's possible. Good luck.
That begs the question. Do I dial back the fuel and risk an even bigger lean spike at activation, or add a 35hp 2nd stage and get up around 400rwhp?
I don't think you should be worried about dyno output numbers, especially whp. You should be worried about how much torque you're making just to hit that 400 horses.
Originally Posted by absurdparadox
people are saying that the Z will handle a 125hp shot fine
People can say that, but my Z's not getting more than 100 whp shot without a proper tune. I still worry when I spray my 100.
I run .061n .036f. This is my last season of experimentation. Next is suspension.
That's a huge nitrous jet! No wonder you're trapping 115.
Just curious, where is your fogger located?
Old Jul 16, 2010 | 10:21 AM
tollboothwilley's Avatar
tollboothwilley
What do you guys normally tune the A/F for when you spray? I've heard 12.0-12.5 with proper tuning is the range. Enlighten me please.
Old Jul 16, 2010 | 12:39 PM
03threefiftyz's Avatar
03threefiftyz
^11:5-11:7. Mild timing as well. Safe is good. Timing is far more important with giggle gas than fatness of the tune...............though it will just as easily go boom if you lean it out without diligence.
Old Jul 16, 2010 | 12:53 PM
ajcool2's Avatar
ajcool2
11's sound good in my auto. Thinking about going for it also. Cant help myself.
Old Jul 16, 2010 | 03:09 PM
3hree5ive0ero
Retired Admin
I would shoot for mid to upper 11s when on the juice. Mine ends up around 11.8:1 toward the end of the rev range. I don't have a tune, though, so I do experience lean spike.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
Juztin
Nov 22, 2015 07:03 AM
