Nitrous Oxide Too soon, jr.
spark plug gap for nitrous?
Old Nov 22, 2003 | 04:54 AM
coletta z's Avatar
coletta z
Default spark plug gap for nitrous?
ok I've done search after search and there are alot of bits and peices of info.So should I use LFR6A-11 plugs gaped at .035.
please respond some of you people w/nitrous also I thought I saw someome who just used the normal (t) adapter to tap the fuel line will this work ?If not what other options do i have besides that pressure adapter alot of people are using?
Any info would really help.Thank You
Old Nov 23, 2003 | 07:02 PM
coletta z's Avatar
coletta z
I know there are alot of people on here using nitrous please share your plug gap size I"m trying to finish my install.Thanks!
Old Nov 23, 2003 | 08:29 PM
webcarconnection's Avatar
webcarconnection
I believe the stock ones goes .44 or something like that... for Nitrous is to open, thats for sure... I bougth the Denso Iridium they are the best for the job... the part # is IKH22 (around $12 each)... I believe some of the sponsors can get them for you... look in the Vendors marketplace!
Hope this Help!!!
Old Nov 24, 2003 | 02:51 AM
02trex's Avatar
02trex
I gapped my Denso Iridiums IKH22 (2 steps colder) at .040 (front 2 cylinders), .038 (middle 2 cylinders), and .036 (rear 2 cylinders). I chose this method because of the way air flow is distributed within the intake plenum and how it affects air/fuel ratio.
I utilized the adapter for the fuel connection for 2 reasons:
1) ease of removal, and
2) I was told by 3 installers that the fuel pressure off the pump was not regulated, so it was not a reliable source. The purpose of the adapter is to install the line after the fuel pressure damper so the delivery is constant. Proper nitrous tuning is dependant, in part, on fuel pressure.
Old Nov 24, 2003 | 03:57 AM
coletta z's Avatar
coletta z
Thanks for the replys I ended up buying the ngk's 1 step coolder and was trying to figure out what other people are gaping these at ?As for the fuel tap how is the pressure different from the line to the damper?Thanks
Old Nov 24, 2003 | 08:32 AM
02trex's Avatar
02trex
I was told that the line pressure from the pump is not well-regulated, therefore it may fluctuate (45psi - 51 psi - 47 psi, etc.) whereas the damper provides a constant pressure to the fuel rails.
I have not tested the pressure off the pump personally but the reason I went with the adapter because the shops told me they would not tap the fuel line because of this issue; installing the adapter was super-easy so I did it myself.
Old Nov 24, 2003 | 10:47 AM
coletta z's Avatar
coletta z
Cool thanks!
Old Dec 27, 2003 | 09:48 AM
MySunset350Z's Avatar
MySunset350Z
hmmm, how important is gapping?
i had the ngk 1 step colder when i was using a 100 shot, and i didnt gap them. used them for a good 3 months without a prob.
im getting the 2 degree colder plugs for next summer, so how important is gapping?
Old Dec 27, 2003 | 10:19 AM
webcarconnection
When you use a 100 shot its not gonna be a big deal... is when you go 100+ that the plug need the to be gapping... but you always have to check the gapping of the plug before install!
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
