Which wires to hook up msd window switch
What wires do I need to tap into to get the rpm window switch to work? Pin numbers? Wire colors? Factory Service manuals would be appreciated.
Exactly what signal do you need? Can you use a single ignition trigger wire? There is no "RPM" signal, just 6 coil trigger wires. So you'd have to set the window switch to be a fraction of the actual RPM you want.
If you can use that type of signal then pins 60, 61, 62, 79, 80, or 81 will work
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
