Question About window Switch
I tried narrowing down what would work last night. I even called MSD to no avail. I am asking of ryour help! Which window switch will work with an 04 350. I was looking into the part # 8969, but am open to any suggestions.
Thanks
Rick
Thanks
Rick
msd part # 8969
its a window switch that doesnt need pills. i have one, but i havent installed it yet. you might want to wait to see if mine works first. i talked to msd and they said it will work on my z which is a 2003.
The 8969 is the correct one. I have gone thru all the B.S. with MSD and this one will work on the 04' Z or G with our output from the coil.
The other WS's require a perfect square wave the 8969 does not.
My works fine
My works fine
My works fine
My works fine
I think for the msd one you do. N/X makes one but requires pills for the RPM you want it to start/stop nitrous at. They come with 3000rpm start and 6000rpm stop pills. Anything else you would have to buy.Im not sure on how both works but I know they are available.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
