5mm wheel spacers
Old Jun 5, 2007 | 12:54 PM
dkorr's Avatar
dkorr
Default 5mm wheel spacers
anyone know which brand is best to buy from in terms of good fitment/quality/cost:
  • H&R
  • EIBACH
  • ICHIBA
  • PROJ KICS
Old Jun 5, 2007 | 01:07 PM
derekinthez's Avatar
derekinthez
Does not really take a whole lot of engineering and the metals are probably the same, I can't see how you could go wrong with any as far as wheel spacers go. In other words, I would not pay for name for this mod.
Old Jun 5, 2007 | 01:21 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I have had H&R and project kics and I prefer the H&R quality more
Old Jun 5, 2007 | 01:44 PM
Batman3's Avatar
Batman3
I have H&R on my car and love them. I have the 20mm..
Old Jun 5, 2007 | 02:18 PM
drivesolo's Avatar
drivesolo
I have the H&R ones, but I didn not use the studs that came w/ them as they do not match the Nissan spline pattern. I used the 50mm Nismo studs instead.
Old Jun 5, 2007 | 02:23 PM
emrgnz's Avatar
emrgnz
H & R
Old Jun 5, 2007 | 05:01 PM
Triple8Sol's Avatar
Triple8Sol
Any of those should be ok, as long as they're hubcentric. I know the H&R and Eibachs are. I've always run H&R and they've been great. Never felt the need to change out the lugs with only 5mm spacers.
Old Jun 6, 2007 | 02:08 PM
dkorr's Avatar
dkorr
thanks everyone... i bought a new pair of ICHIBAs 5mm for under $60
Old Jun 6, 2007 | 02:23 PM
johnlotusboy's Avatar
johnlotusboy
Upgarage in Tacoma has them for $10 a pair without studs. Depends on the thickness of your rim bolt seat area, whether you need studs.
Old Jun 6, 2007 | 07:38 PM
lpphreakx06's Avatar
lpphreakx06
H&R but not unless you REALLY need them. My friend had his studs snap once. Not a pleasant experience.
Old Jun 6, 2007 | 11:30 PM
Triple8Sol's Avatar
Triple8Sol
But are they hubcentric?
Old Jun 7, 2007 | 07:48 AM
johnlotusboy
@ 5mm it doesn't matter because your snout on the spindle sticks more than 5mm's thru the rotor.
What you trying to acomplish with 5mm shims?
I use 5mm shims to bring my RPF-1's back to 30mm from 35mm. The 5mm on each side corrects the SAI (steering axis inclination). This makes the car drive much more comfortably down our rutted roads. The car feels alot more "stock" even with 275's on the front and nothing that is OEM in the whole suspension.
Old Jun 7, 2007 | 08:46 AM
drivesolo's Avatar
drivesolo
^ I believe that's what his goal is. He's considering optimizing his wheel & tire setup for autoX purposes.
Obadabot
Jun 18, 2023 11:31 PM
