need some help and opinions
Old Feb 19, 2008 | 05:24 PM
travismaser's Avatar
travismaser
Default need some help and opinions
first off i need help trying to find engine mounts for my 06 z...iv searched and looked around online...and all i found was a damper.... is that gnna be enough?
second...im looking for a front lip...what style do u guys like?
im looking at the greddy lip but i dnno if it would look good without the rest of the kit?...i really dnt have the 900$ for the sides and rear
Old Feb 19, 2008 | 05:27 PM
SlowZster's Avatar
SlowZster
why on earth would you need new engine mounts?
Old Feb 19, 2008 | 05:35 PM
travismaser
well i have the Turbo-XS test tubes and the nismo exhaust and i keep cracking the welds on the test tubes and on the res.....i cant think of another explaination other then the mounts are bad....
im not using the test tube mounts anymore because they kept snaping off
Old Feb 19, 2008 | 05:38 PM
Mixturepinoy's Avatar
Mixturepinoy
well... there's your problem.. test tubes don't come stock
Old Feb 19, 2008 | 05:41 PM
SlowZster's Avatar
SlowZster
i don't even know ho wto respond to that 1...
it's test pipes, not test tubes...test tubes are what tito posted up.
Old Feb 19, 2008 | 05:43 PM
travismaser
haha yea that was a dumb mistake on my part aha...u all know what i ment haha
Old Feb 19, 2008 | 07:05 PM
Triple8Sol's Avatar
Triple8Sol
Did you check companies like energy suspension?
Old Feb 19, 2008 | 08:39 PM
travismaser
no but i deff will..thank u
Old Feb 19, 2008 | 10:36 PM
overZealous1's Avatar
overZealous1
i make solid mounts, but i'm sure the main prob your having is due to junk robotic welds. alot of them do not use filler rod in the welds and just melt the 2 metals together. creates a weak spot at the weld.
Old Feb 20, 2008 | 01:23 AM
travismaser
humm....well i rewelded every weld on the exhaust today...and within a day i already have a new leak.....i wont be able to get it back on the lift till thursday so yea.....pretty ticked off....i think im deff gnna buy a damper and if that doesent work then buy some solid mounts.....
Old Feb 20, 2008 | 07:23 AM
HaulinZ's Avatar
HaulinZ
where did you get these test pipes?
Old Feb 20, 2008 | 08:17 AM
240Zplus110's Avatar
240Zplus110
I installed the engine damper and the plus was that there is less movement in the engine under torque. The down-side is that any engine vibration has an easier path to the frame -- more noticeable on decerleration.
Energy makes good mounts -- stiffer than OEM but not solid... IIRC.
Old Feb 20, 2008 | 12:12 PM
travismaser
i bought them off a friends friend..haha they were used for about a month from what i understand but then he sold his car
Old Feb 20, 2008 | 12:18 PM
travismaser
Topspeed Pro-1?.....is that a pretty good damper from anyones experiance?
Old Feb 20, 2008 | 03:22 PM
Triple8Sol's Avatar
Triple8Sol
jwinn, first350, and sdbarker are the locals that I know have that part. Many, many others nationally, though. It's basically a Stillen replica.
Old Feb 20, 2008 | 03:59 PM
Jeff92se's Avatar
Jeff92se
Flex section
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
wanderingstuden
Jan 28, 2016 07:03 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
