Basic or ISO Thermal Plenum Spacer?!
Old Jul 30, 2008 | 02:31 PM
Deedlebop's Avatar
Deedlebop
Default Basic or ISO Thermal Plenum Spacer?!
So i'm going to buy a plenum spacer like NOW and I need to know if the ISO thermal spacer is that much better or if the price is just higher because of a few added no-big-deal parts...someone knowledgeable please fill me in! Info on the spacers is here:
http://motordyneengineering.com/350Z.php
Old Jul 30, 2008 | 02:32 PM
Deedlebop's Avatar
Deedlebop
Keep in mind I do live in WA..so is the CCV that important? LMK please!
Old Jul 30, 2008 | 02:48 PM
SlowZster's Avatar
SlowZster
get the iso thermal 5/16. Don't get the 1/2 unless you don't like your strut bar and engine cover (if I remember right)
Old Jul 30, 2008 | 02:49 PM
SlowZster's Avatar
SlowZster
also, what year is your car? If you have the rev-up motor, I would definately recommend the MREV2
Old Jul 30, 2008 | 03:04 PM
redlude97's Avatar
redlude97
go with the iso thermal so you don't have to deal with the coolant valve and the changing weather in WA
Old Jul 30, 2008 | 04:38 PM
Deedlebop's Avatar
Deedlebop
I have an 03. So the ISO thermal 5/16 is the way to go? I believe those come with the CCV...the copper one is the only one that is "premium"..but if I don't have to change anything right now regarding the outside temperature..why would I have to when I get the plenum?
Old Jul 30, 2008 | 04:55 PM
HaulinZ's Avatar
HaulinZ
im running the basic 5/16 never had any problems..
Old Jul 30, 2008 | 05:20 PM
redlude97's Avatar
redlude97
The basic spacer comes with a valve that bypasses the coolant that flows through the throttle body to prevent it from heating up the plenum, but in the winter this can lead to a frozen throttle body, so you have to turn the valve back on in the winter. The premium isothermal kit comes with a isothermal gasket that goes between the throttle body and plenum to prevent the heat soak so the coolant bypass is no longer necessary.
Old Aug 4, 2008 | 11:27 AM
tylerxfire's Avatar
tylerxfire
i don't drive my car in the winter, should i just get the iso, i mean i just start it once and a while will it be fine to leave it bypassed to just start it every once in a while
Old Aug 5, 2008 | 06:16 PM
SlowZster's Avatar
SlowZster
I would still get it
Old Aug 5, 2008 | 06:36 PM
tylerxfire's Avatar
tylerxfire
i did, i am told it is just a valve that bypasses something, not really sure till i see it, should be here tomorrow, and you can turn it on or off i don't know, fill me in if you know please so i know what to expect
Old Aug 5, 2008 | 06:44 PM
SlowZster's Avatar
SlowZster
it does have a valve that you have to cut into one of your lines to install that you can turn on or off. I didn't put it on though.
