Whhyyy
Old Jan 18, 2005 | 11:00 AM
350fanatic's Avatar
350fanatic
Unhappy Whhyyy
everytime i peel my tires, why do i hear a thudding noise??
the car shakes and sounds like soemthing is goin to break.
i noticed this at infineon, is this the wheel hoppin around or something?
when i get my drag radials will that solve the problem?
Old Jan 18, 2005 | 12:48 PM
arvin's Avatar
arvin
Are you hearing things again? I told you to lay off that sh*t.
Do you have VDC?
Old Jan 18, 2005 | 12:59 PM
350fanatic's Avatar
350fanatic
yeh, well of course im turning it off before i do a burnout
Old Jan 18, 2005 | 03:10 PM
350fanatic's Avatar
350fanatic
anyone else have this problem?
Old Jan 19, 2005 | 10:55 PM
spf4000's Avatar
spf4000
Thudding? You must be talking about wheel hop. Why are you peeling out at Infineon...oh wait, you must be going to the drags.
Try lowering your tire pressure and get stronger shocks to absorb the wheel hop.
Old Jan 19, 2005 | 10:57 PM
z_drifto's Avatar
z_drifto
I got mad wheelhop when I was at infineon too and at Sac raceway. You have stock tires huh? They tend to hop around a bit and, as we like to say in the industry, suckass.
Old Jan 20, 2005 | 10:02 PM
fowlman01's Avatar
fowlman01
Sure sounds like wheel hop. I seldom have it. I have more of a problem with total loss of traction in first and second. You want the tires to spin slightly, but not a whole lot. I have a nismo s suspension and pilot sports, so that helps. Probably why I don't have wheel hop often.
Old Jan 23, 2005 | 11:00 PM
4myZ350's Avatar
4myZ350
Default Re: Whhyyy---no air
[QUOTE]Originally posted by 350fanatic
[B]everytime i peel my tires, why do i hear a thudding noise??
put air in them--LOLing --- thud thud thud is a flat ha ha ha
Old Jan 23, 2005 | 11:04 PM
krinkov's Avatar
krinkov
get some poly sub-frame bushings or sub-frame locks, that will take care of it
Old Jan 24, 2005 | 05:52 AM
fowlman01's Avatar
fowlman01
Default Re: Re: Whhyyy---no air
[QUOTE][
[B]
everytime i pee my tires, why do i hear a thudding noise??
JOck---why r-u peeing on your tirews???---??
Old Jan 24, 2005 | 12:51 PM
350fanatic's Avatar
350fanatic
exactly what is that?
Old Jan 24, 2005 | 05:38 PM
krinkov's Avatar
krinkov
hmm, I had a feeling you Z33 guys didnt have these yet, the main culprits for wheel hop are the soft rubber subframe bushings, us Z32s have used poly subframe bushings bushings or solid aluminum subframe locks to get rid of it, I'd be really surprised if they didnt have these available for the Z33 by now since it has the same type pf rear subframe and also has wheel hop, search around
