looking for for honest dyno numbers
Old Apr 20, 2006 | 09:41 AM
drives4fun's Avatar
drives4fun
Default looking for for honest dyno numbers
friend and i installed borla exhaust,test pipes,kinetix intake,jwt pop, looking for a chip and dyno tuning and testing where do i go. need before and after numbers
Old Apr 20, 2006 | 09:46 AM
chuckie311's Avatar
chuckie311
why dont you try technosquareinc.com
Old May 4, 2006 | 09:24 AM
drives4fun's Avatar
drives4fun
Thanks for the info. do you know what kind of dyno they have? Is is dynojet?
Old May 4, 2006 | 09:27 AM
barthelb's Avatar
barthelb
Master
Zcargarage 408 452 0350
They have a dynojet, load based dyno.
Numbers are very realistic and not inflated.
Old May 4, 2006 | 10:03 AM
ZON's Avatar
ZON
Give Ted a call at Scott Performance in Santa Clara, www.scottperformance.us
Tunes on Dastek load dyno. Sells, installs & tunes Unichip and the dyno is very very accurate. SP is Z cars & G35's only.
Old May 15, 2006 | 12:53 PM
drives4fun's Avatar
drives4fun
thanks for the information. Does anyone know the difference between the two dyno's?
Old May 15, 2006 | 02:46 PM
barthelb's Avatar
barthelb
Master
Dynojet is kinda the standard in the States, you'll find most places using either Dynojet or I've seen Mustang Dyno's. Not all but most around here.
Dastek is an Australian Brand dyno that coincidentally the APS guys recommend for tuning. So, it is up to you. If the dynojet is setup to the proper load assuming its the newer load based dyno, you will get a more conservative honest dyno. The dastek seems to read higher numbers. Now if your tuning on it then it doesn't really matter as long as the net number difference in baseline vs. after mod or tuning dyno shows the same gain.
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
