Headlight went out..
Old May 2, 2009 | 01:38 PM
domsaywha's Avatar
domsaywha
Default Headlight went out..
Err i try searching the forums to see how to change my headlight bulbs because it went out, but i had no luck finding a guide. Any ideas?
Old May 2, 2009 | 02:15 PM
johnha209's Avatar
johnha209
its a pain in the buttt.. haha... thats all i got to say.. =)
Old May 2, 2009 | 04:11 PM
omega6's Avatar
omega6
Go to the forum, DIY: blacked out head light "Laisifu's" post - it's the same directions to get to your headlight.
1 - remove your rim
2 - remove the plastic gaurd to get behind your headlight
3 - now you have access to your headlight form the rear
Old May 2, 2009 | 10:08 PM
threetothefour's Avatar
threetothefour
yea mine went out too... so i just changed it yesterday. it took me hella long time tho... When Brandon helped me, he did it within 20~30 mins but it took me like at least an hour and half to take it out and install them back. basically, the easiest way is to take out your bumper and then your headlights and change bulbs that you need to change and put them all back together. it wasnt easy for me, i tell you that. if you are really close by me, i can help you out but otherwise, GL
Old May 3, 2009 | 11:19 AM
domsaywha's Avatar
domsaywha
Alright, Thanks!
Old May 6, 2009 | 09:48 AM
jcperformance's Avatar
jcperformance
The headlight has to come out in order to replace the light. You will need to remove the bolts connecting the light in the engine compartment, there is also a bolt in the fender well. It is a pain if you don't know what you are doing I would recommend have someone do it for you. Replace all of the bulbs while you are in there. Good luck. Let me know if you want me to do it for you. You can swing by my shop.
Old May 6, 2009 | 10:18 AM
anotheraznguy's Avatar
anotheraznguy
you do not need to take the headlights out..
you only need to take the splash shield off and you can get to the bulb from there.
Old May 6, 2009 | 03:34 PM
domsaywha's Avatar
domsaywha
friends body shop did it! thanks tho guys,
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
